用Vivado-HLS实现低latency 除法器
6222|12
GoldSunMonkey|  楼主 | 2013-3-25 18:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1         Vivado HLS 简介
2         创建一个Vivado-HLS工程
2.1      打开Vivado HLS GUI
2.2      创建新工程
2.3      添加源文件
2.4      添加测试文件
2.5      创建solution
3         C Validation
4         C Synthesis. 13
5         Explore 不同新的Solution. 15
1      Vivado HLS 简介
        Xilinx Vivado High-Level Synthesis (HLS) 工具将 C, C++,或者 SystemC 设计规范,算法转成 Register Transfer Level (RTL)实现,可综合到Xilinx FPGA。
  • 将DSP算法快速转到RTL FPGA 实现
  • 将C 至 RTL时间缩短 4 倍
  • 基于 C 语言的验证时间缩短100倍
  • RTL 仿真时间缩短 3 倍
2      创建一个Vivado-HLS工程 2.1      打开Vivado HLS GUI
       双击桌面上Vivado HLS GUI 图标, 或从Start > All Programs >
       Vivado <version> > Vivado HLS GUI
       打开GUI之后,Vivado-HLS welcome界面如下所示:
2.2      创建新工程
       在 Welcome Page, 选择Create New Project
2.3      添加源文件
       指定顶层需要综合的源文件名,并添加文件.
       本除法器设计采用移位算法
#include "radix2div.h"
quotient_t radix2div (
        dividend_t   dividend,  // (numerator)
        divisor_t    divisor,   // (denominator)
        remainder_t   *remainder  //
#pragma AP latency max=3
#pragma AP pipeline
  quotient_i_t quo, y;          // <quo>+1 bits unsigned
  subtract_t   sub_out, rem_r;    // <divisor>+1 bits signed
  boolean_t    last_bit, next_bit;
  loop_cnt_t   i;
  last_bit = 0;
  rem_r = 0;
  if (LOOP_MAX > 32)
    quo = 0ULL;
else
    quo = 0;
  div_booth_label0:  for (i = 0; i < LOOP_MAX; i = i+1) {
        // concurrent blocks
        sub_out = rem_r - divisor;
        y = dividend & 1 <<  (LOOP_MAX-i-2);
        if ( y == 0 )
            next_bit = 0;
        else
            next_bit = 1;
       if (sub_out < 0) { // remainder - denominator is negative
            quo = quo << 1;
            if (i != LOOP_MAX-1) {
                rem_r = rem_r << 1;
                rem_r = rem_r | next_bit;
        else { // remainder - denominator is positive
            quo = quo << 1;
            quo = quo | 1;
                rem_r = sub_out << 1;
            else
              rem_r = sub_out;
      } // end for
*remainder = rem_r;
return quo;
2.4      添加测试文件
       添加测试文件.
#include <stdio.h>
#include <math.h>
int test_divider (dividend_t    dividend,
                  divisor_t     divisor
    quotient_t quotient;
    remainder_t remainder;
    quotient = radix2div(dividend,divisor,&remainder);
    fprintf(stdout, ">>>>>>>>> dividend = %u,  divisor = %u   quotient = %u   remainder = %u \n",
             dividend, divisor, quotient, remainder);
    fprintf(stdout, ">>>>>>>>>-------------------- \n");
    if ((quotient == dividend/divisor) && (remainder == dividend-(divisor*quotient)) ) {
        printf ("PASS \n");
    else {
        printf ("FAIL \n");
        return 1;
int main () {
int i, j;
dividend_t max_num;
max_num = 0;
j = LOOP_MAX-1;
for (i = 0; i < j; i = i+1) {
  max_num = max_num + pow(2,i);
test_divider (max_num,1);
test_divider (2,pow(2,9)-1);
test_divider (max_num,pow(2,9)-1);
test_divider (8,1);
test_divider (99,10);
2.5      创建solution
       创建solution, 时钟约束, 并选器件.
       打开包括工程信息Vivado HLS GUI.
3      C Validation
       在将c/c++/system c 转换成RTL之前,必须先验证C 设计,确保其功能是正确的
       点击 “Run C Simulation” 图标,
4      C Synthesis
       现在可以对设计做C 综合,生成RTL代码. 当综合完成,, GUI 更新综合结果. 包括资源使用,latency等。
        为了达到了预先要求为3 个时钟周期, 将latency 的directive设置为3。
       project -> new solution。
       在同一个工程里面,可以使用同一套源代码,进行不同solutions的尝试。
---end---
评分
参与人数 1威望 +5 收起 理由
jakfens + 5 哈哈 给力
yuqq| | 2013-3-25 20:54 | 只看该作者
用 Vivado HLS这个工具生成的网表能在中低端的板子上用吗?
jakfens| | 2013-3-25 21:29 | 只看该作者
的÷÷哈哈 good job 这个喜欢
pontiff| | 2013-3-25 21:35 | 只看该作者
猴哥还在这混呢,还以为搬家了呢
GoldSunMonkey|  楼主 | 2013-3-25 23:57 | 只看该作者
目前支持7系列和ZYNQ
jakfens 发表于 2013-3-25 21:29
的÷÷哈哈 good job 这个喜欢
欢迎啊
pontiff 发表于 2013-3-25 21:35
猴哥还在这混呢,还以为搬家了呢
没有啊
george7042646| | 2013-4-15 15:33 | 只看该作者
厉害厉害,这也能做的这么出色,果然是有高手在啊。。受益匪浅
hardfire| | 2013-4-15 16:08 | 只看该作者
哇,厉害,顶下。
Backkom80| | 2013-4-15 17:38 | 只看该作者
xuxikfg| | 2013-4-15 21:25 | 只看该作者
明显厉害人物
lelee007| | 2013-4-15 21:47 | 只看该作者
犀利
GoldSunMonkey|  楼主 | 2013-4-18 20:43 | 只看该作者
lelee007 发表于 2013-4-15 21:47
犀利
感谢
个人签名:                     2014, 追逐梦想
264
