[Cortex-M0技术交流]
LPC1114 uart发送问题
2434|1
zero0915|  楼主 | 2013-9-26 14:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠,小弟现在在搞一块LPC1114的板子,用的坏境是IAR6.3,在测试uart时,发现用IAR上自带的例程可以收发,例程是用中断将受到的数据在用查询发回电脑。但是我自己加了个发字节的函数都总是发不了,请同事也看过了,也找不到原因。现在有点困扰,想请大家帮忙看看。
附上代码 除了 UARTSendByte 其他都是例程自带的。
中断处理
** Function name:                UART0_IRQHandler
** Descriptions:                UART interrupt handler
** parameters:                        None
** Returned value:                None
#pragma diag_suppress=Pa082
void UART0_IRQHandler(void)
  uint8_t IIRValue, LSRValue;
  uint8_t Dummy = Dummy;
  IIRValue = LPC_UART->IIR;    // interrupt ID Register
  IIRValue >>= 1;                        /* skip pending bit in IIR */
  IIRValue &= 0x07;                        /* check bit 1~3, interrupt identification */
  if (IIRValue == IIR_RLS)                /* Receive Line Status */
    LSRValue = LPC_UART->LSR;           /* Receive Line Status */
    if (LSRValue & (LSR_OE | LSR_PE | LSR_FE | LSR_RXFE | LSR_BI))
      /* There are errors or break interrupt */
      /* Read LSR will clear the interrupt */
      UARTStatus = LSRValue;
      Dummy = LPC_UART->RBR;        /* Dummy read on RX to clear
        interrupt, then bail out */
      return;
    if (LSRValue & LSR_RDR)        /* Receive Data Ready */
      /* If no error on RLS, normal ready, save into the data buffer. */
      /* Note: read RBR will clear the interrupt */
      UARTBuffer[UARTCount++] = LPC_UART->RBR;
      if (UARTCount == BUFSIZE)
        UARTCount = 0;                /* buffer overflow */
  else if (IIRValue == IIR_RDA)        /* Receive Data Available */
  else if (IIRValue == IIR_CTI)        /* Character timeout indicator */
    /* Character Time-out indicator */
    UARTStatus |= 0x100;                /* Bit 9 as the CTI error */
  else if (IIRValue == IIR_THRE)        /* THRE, transmit holding register empty */
    /* THRE interrupt */
    LSRValue = LPC_UART->LSR;                /* Check status in the LSR to see if
        valid data in U0THR or not */
    if (LSRValue & LSR_THRE)
      UARTTxEmpty = 1;
    else
      UARTTxEmpty = 0;
  return;
#pragma diag_default=Pa082
发送字符串
** Function name:                UARTSend
** Descriptions:                Send a block of data to the UART 0 port based
**                                on the data length
** parameters:                buffer pointer, and data length
void UARTSend(uint8_t *BufferPtr, uint32_t Length)
  while ( Length != 0 )
          /* THRE status, contain valid data */
#if !TX_INTERRUPT
          LPC_UART->THR = *BufferPtr;
          while ( !(LPC_UART->LSR & LSR_THRE) ); //polling
#else
          /* Below flag is set inside the interrupt handler when THRE occurs. */
      while ( !(UARTTxEmpty & 0x01) );
      UARTTxEmpty = 0;        /* not empty in the THR until it shifts out */
#endif
      BufferPtr++;
      Length--;
  return;
发字节
** Function name:                UARTSendByte
void UARTSendByte(uint8_t dat)
          LPC_UART->THR = dat;
main
int main (void) {
  SystemInit();
  /* NVIC is installed inside UARTInit file. */
  UARTInit(9600);
#if MODEM_TEST
  ModemInit();
#endif
UARTSendByte(0xaa);
  while (1)
   /* Loop forever */
        if ( UARTCount != 0 )
          LPC_UART->IER = IER_THRE | IER_RLS; /* Disable RBR */
           UARTSendByte(0xaa);
          UARTSend( (uint8_t *)UARTBuffer, UARTCount );
          UARTCount = 0;
          LPC_UART->IER = IER_THRE | IER_RLS | IER_RBR;        /* Re-enable RBR */
zero0915|  楼主 | 2013-9-29 22:01 | 只看该作者
没人给点意见吗
