13.56 MHz. RFID HF Jewellery Tag
890|1
gaofrid|  楼主 | 2008-8-7 10:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Type    Contactless Read/Write
Operating Frequency    13.56 MHz
Capacity    512 bits R/W
Data Coding Type    Manchester, Biphase, PSK
Common Usage    Asset Tracking, Access Control, and Inventory Management
Standard Deployment    Attached to object or inserted into object
Tested Read Range    2 - 4 cm ( 1- 2 in.)
Multi-Detection    No
Max read quantity    1 tags/sec
Size    L 25mm x W 15mm
Material    PVC plastic
Color    White
Weight    0.5 g
Compliance    ICODE SLI or other compatible ICs
Operating Specifications    Temperature:storage at Storge at - 55°C to +100°C, Operating at -40°C to 85°C
For further information on this product, or for assistance in finding a different RFID product to meet your specification, please Contact Us.
About GAO RFID Inc.
GAO RFID Inc. is a leading provider of Radio Frequency Identification (RFID) hardware and solutions to end users worldwide. GAO RFID combines best of breed with low cost RFID readers, RFID tags and enabling-RFID software. We have a wide variety of RFID readers, tags and antennas in all the RFID technologies, Low Frequency (LF), High Frequency (HF), Ultra High Frequency (UHF, Gen 2) as well as Active and Semi-Passive.  GAO RFID’s products and services are easily customized for use in Asset Tracking,  Health care, Supply Chain & Logistics, Event Management, Access Control, Livestock Tracking, Inventory Control & Management, Field Service, Maintenance and Document Authentication.
For more information please visit http://www.GAORFID.com
gaofrid|  楼主 | 2008-8-8 09:19 | 只看该作者
13.56 MHz. High Frequency (HF) Square Paper RFID Tag
Model: 113002
Type:    Contactless Read/Write
Operating Frequency:     13.56 MHz. (HF-High Frequency).
Capacity:     512 bit up to 10Kbits
Common Usage:     Ticketing, Library Management, anti-counterfeiting
Standard Deployment:     Electronic label application, Electronic Article Surveillance
Tested Read Range:     Maximum 10cm Read and Write, the distance may vary depend upon the reader/environment)
Multi-Detection:     Yes
Max read quantity:     30 labels/sec
Size:     43mm x 43mm
Material:     Opaque matt paper 79
Color:     White
Weight:     0.5g
Compliance:    ICODE, SLI
Regulatory Specifications:    ISO 15693
Operating Specifications:    Waterproof and dustproof
    Resistance to immersion in salt water, alcohol, oil, 10% HCL,
    Ammonia =
    Shock – Dependant on packaging
    Vibration – Dependant on packaging
    Temperature – Storage –40°C to +85°C
    - Operating -25°C to + 70°C
About GAO RFID Inc.
