28335ADC配置
3088|4
kangwuwei|  楼主 | 2014-8-11 10:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
28335的AD如何配置呀 我从例程ADC的程序把通道ADCIN0 改成到了ADCIN1后 没有转化数据出现,如何做
InitAdc();         // For this example, init the ADC
  // Specific ADC setup for this example:
     AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;  // Sequential mode: Sample rate   = 1/[(2+ACQ_PS)*ADC clock in ns]
                          //                     = 1/(3*40ns) =8.3MHz (for 150 MHz SYSCLKOUT)
                                              //                     = 1/(3*80ns) =4.17MHz (for 100 MHz SYSCLKOUT)
                                              // If Simultaneous mode enabled: Sample rate = 1/[(3+ACQ_PS)*ADC clock in ns]
     AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
     AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;        // 1  Cascaded mode
     AdcRegs.ADCTRL1.bit.CONT_RUN = 1;       // Setup continuous run
   //  AdcRegs.ADCTRL1.bit.ADCBSYCHN =
     AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;       // Enable Sequencer override feature
     AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x01;
     AdcRegs.ADCCHSELSEQ2.all = 0x0;
     AdcRegs.ADCCHSELSEQ3.all = 0x0;
     AdcRegs.ADCCHSELSEQ4.all = 0x0;
     AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x1;
     AdcRegs.ADCTRL2.all = 0x2000;
     scic_fifo_init();           // Initialize the SCI FIFO
          scic_echoback_init();  // Initalize SCI for echoback
          msg = "\r\n\n\nHello World!\0";
          scic_msg(msg);
          msg = "\r\nIf you change the ADC Res,we will give you the value! \n\0";
          scic_msg(msg);
// Enable global Interrupts and higher priority real-time debug events:
    //EINT;   // Enable Global interrupt INTM
   // ERTM;   // Enable Global realtime interrupt DBGM
        i = 0;
    for(; ;)
            // LED_pulse();
            PM2_5_reg = ~0x40;
            DELAY_US(260);
            while(AdcRegs.ADCST.bit.INT_SEQ1 == 0);
            AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
       ADCValue[0] = ( (AdcRegs.ADCRESULT0) >>4);
       PMvalue = ADCValue[0];
     // PMvalue = ((double)PMvalue /4096) *3*3/2;
     //  PMvalue = (PMvalue-0.0356)*120000 * 0.127 -0.0999;
       sprintf(cbuf,"tne PM2.5 is %d\n",ADCValue[0]);
            DELAY_US(20);
            PM2_5_reg = 0x40;
            DELAY_US(9680);
            DELAY_US(200000);
            scic_msg(cbuf);
wangch_sh| | 2014-8-11 16:32 | 只看该作者
这还是ADC0啊!
zhangmangui| | 2014-8-11 22:57 | 只看该作者
楼上说的有道理
kangwuwei|  楼主 | 2014-8-14 09:58 | 只看该作者
AdcRegs.ADCRESULT1也不行
zhangmangui| | 2014-8-14 23:26 | 只看该作者
参考一下分享的资料吧
里面看看有没有ADC的代码  供你参考排查一下寄存器的配置
DSP28335资料分享
个人签名:修行
26
