求翻译。。求帮助
1017|0
 楼主| hanke998 发表于 2014-9-23 17:49 | 显示全部楼层 |阅读模式
entity dac3283_ctrl is
generic (
  START_ADDR      : std_logic_vector(27 downto 0) := x"0000000";
  STOP_ADDR       : std_logic_vector(27 downto 0) := x"00000FF"
port (
  rst             : in  std_logic;
  clk             : in  std_logic;
  -- Sequence interface
  init_ena        : in  std_logic;
  init_done       : out std_logic;
  -- Command Interface
  clk_cmd         : in  std_logic;
  in_cmd_val      : in  std_logic;
  in_cmd          : in  std_logic_vector(63 downto 0);
  out_cmd_val     : out std_logic;
  out_cmd         : out std_logic_vector(63 downto 0);
  in_cmd_busy     : out std_logic;
  -- SPI control
  spi_n_oe        : out std_logic;
  spi_n_cs        : out std_logic;
  spi_sclk        : out std_logic;
  spi_sdo         : out std_logic;
  spi_sdi         : in  std_logic
end dac3283_ctrl;
architecture dac3283_ctrl_syn of dac3283_ctrl is
component fmc150_stellar_cmd is
generic
port
  reset                : in  std_logic;
  clk_cmd              : in  std_logic;                     --cmd_in and cmd_out are synchronous to this clock;
  -- Register interface
  clk_reg              : in  std_logic;                     --register interface is synchronous to this clock
  out_reg              : out std_logic_vector(31 downto 0); --caries the out register data
  out_reg_val          : out std_logic;                     --the out_reg has valid data  (pulse)
  out_reg_addr         : out std_logic_vector(27 downto 0); --out register address
  in_reg               : in  std_logic_vector(31 downto 0); --requested register data is placed on this bus
  in_reg_val           : in  std_logic;                     --pulse to indicate requested register is valid
  in_reg_req           : out std_logic;                     --pulse to request data
  in_reg_addr          : out std_logic_vector(27 downto 0);  --requested address
  --mailbox interface
  mbx_in_reg           : in  std_logic_vector(31 downto 0); --value of the mailbox to send
  mbx_in_val           : in  std_logic                      --pulse to indicate mailbox is valid
end component fmc150_stellar_cmd;
component  pulse2pulse
port (
  rst      : in  std_logic;
  in_clk   : in  std_logic;
  out_clk  : in  std_logic;
  pulsein  : in  std_logic;
  pulseout : out std_logic;
  inbusy   : out std_logic
end component;
component dac3283_init_mem is
port (
  clka  : in  std_logic;
  addra : in  std_logic_vector(4 downto 0);
  douta : out std_logic_vector(15 downto 0)
end component;
constant ADDR_GLOBAL  : std_logic_vector := x"0000020";
constant ADDR_MAX_WR  : std_logic_vector := x"000001F";
constant ADDR_MAX_RD  : std_logic_vector := x"000001F";
type sh_states is (idle, instruct, data_io, data_valid);
signal sh_state       : sh_states;
signal serial_clk     : std_logic;
signal sclk_ext       : std_logic;
signal out_reg_val    : std_logic;
signal out_reg_addr   : std_logic_vector(27 downto 0);
signal out_reg        : std_logic_vector(31 downto 0);
signal in_reg_req     : std_logic;
signal in_reg_addr    : std_logic_vector(27 downto 0);
signal in_reg_val     : std_logic;
signal in_reg         : std_logic_vector(31 downto 0);
signal done_sclk      : std_logic;
signal init_done_sclk : std_logic;
signal init_done_tmp  : std_logic;
signal init_done_prev : std_logic;
signal init           : std_logic;
signal init_tmp       : std_logic;
signal init_reg       : std_logic;
signal inst_val       : std_logic;
signal inst_reg_val   : std_logic;
signal inst_rw        : std_logic;
signal inst_reg       : std_logic_vector(4 downto 0);
signal data_reg       : std_logic_vector(7 downto 0);
signal sh_counter     : integer;
signal shifting       : std_logic;
signal read_n_write   : std_logic;
signal ncs_int        : std_logic;
signal busy           : std_logic;
signal sdi            : std_logic;
signal shift_reg      : std_logic_vector(15 downto 0);
signal init_address   : std_logic_vector(4 downto 0);
signal init_data      : std_logic_vector(15 downto 0);
signal read_byte_val  : std_logic;
signal data_read_val  : std_logic;
signal data_read      : std_logic_vector(7 downto 0);
begin
-- Generate serial clock (max 20MHz)
process (clk)
  -- Divide by 2^4 = 16, CLKmax = 16 x 20MHz = 320MHz
  variable clk_div : std_logic_vector(3 downto 0) := (others => '0');
begin
  if (rising_edge(clk)) then
    clk_div    := clk_div + '1';
    -- The slave samples the data on the rising edge of SCLK.
    -- therefore we make sure the external clock is slightly
    -- after the internal clock.
    sclk_ext   <= clk_div(clk_div'length-1);
    serial_clk <= sclk_ext;
  end if;
end process;
-- Stellar Command Interface
fmc150_stellar_cmd_inst : fmc150_stellar_cmd
generic map
  START_ADDR   => START_ADDR,
  STOP_ADDR    => STOP_ADDR
port map
  reset        => rst,
  clk_cmd      => clk_cmd,
  in_cmd_val   => in_cmd_val,
  in_cmd       => in_cmd,
  out_cmd_val  => out_cmd_val,
  out_cmd      => out_cmd,
  clk_reg      => clk,
  out_reg_val  => out_reg_val,
  out_reg_addr => out_reg_addr,
  out_reg      => out_reg,
  in_reg_req   => in_reg_req,
  in_reg_addr  => in_reg_addr,
  in_reg_val   => in_reg_val,
  in_reg       => in_reg,
  mbx_in_val   => '0',
  mbx_in_reg   => (others => '0')
-- Shoot commands to the state machine
process (rst, clk)
begin
  if (rst = '1') then
    init_done      <= '0';
    init_done_tmp  <= '0';
    init_done_prev <= '0';
    init           <= '0';
    in_reg_val     <= '0';
    in_reg         <= (others => '0');
    inst_val       <= '0';
    inst_rw        <= '0';
    inst_reg       <= (others=> '0');
    data_reg       <= (others=> '0');
  elsif (rising_edge(clk)) then
    init_done      <= init_done_sclk;
    init_done_tmp  <= done_sclk;
    init_done_prev <= init_done_tmp;
    -- Release the init flag on rising edge init done
    if (init_done_tmp = '1' and init_done_prev = '0') then
      init <= '0';
    -- Enable the init flag when enable flag is high, but done flag is low
    elsif (init_ena = '1' and init_done_tmp = '0') then
      init <= '1';
    -- There is one additional status and control register available
    elsif (out_reg_val = '1' and out_reg_addr = ADDR_GLOBAL) then
      init <= out_reg(0);
    end if;
    if (in_reg_req = '1' and in_reg_addr = ADDR_GLOBAL) then
      in_reg_val <= '1';
      in_reg     <= conv_std_logic_vector(0, 27) & '0' & busy & '0' & '0' & init_done_prev;
    -- read from serial if when address is within device range
    elsif (in_reg_addr <= ADDR_MAX_RD) then
      in_reg_val <= data_read_val;
      in_reg     <= conv_std_logic_vector(0, 24) & data_read;
    else
      in_reg_val <= '0';
      in_reg     <= in_reg;
    end if;
    -- Write instruction, only when address is within device range
    if (out_reg_val = '1' and out_reg_addr <= ADDR_MAX_WR) then
      inst_val <= '1';
      inst_rw  <= '0'; -- write
      inst_reg <= out_reg_addr(4 downto 0);
      data_reg <= out_reg(7 downto 0);
    -- Read instruction, only when address is within device range
    elsif (in_reg_req = '1' and in_reg_addr <= ADDR_MAX_RD) then
      inst_val <= '1';
      inst_rw  <= '1'; -- read
      inst_reg <= in_reg_addr(4 downto 0);
      data_reg <= data_reg;
    -- No instruction
    else
      inst_val <= '0';
      inst_rw  <= inst_rw;
      inst_reg <= inst_reg;
    end if;
  end if;
end process;
-- Intruction pulse
pulse2pulse_inst0 : pulse2pulse
port map
  rst      => rst,
  in_clk   => clk,
  out_clk  => serial_clk,
  pulsein  => inst_val,
  pulseout => inst_reg_val,
  inbusy   => open
-- Serial interface state-machine
process (rst, serial_clk)
begin
  if (rst = '1') then
    init_tmp     <= '0';
    init_reg     <= '0';
    sh_state     <= idle;
    sh_counter   <= 0;
    shifting     <= '0';
    read_n_write <= '0';
    ncs_int      <= '1';
  elsif (rising_edge(serial_clk)) then
    -- Double synchonise flag from other clock domain
    init_tmp <= init;
    init_reg <= init_tmp;
    -- Main state machine
    case sh_state is
      when idle =>
        sh_counter <= shift_reg'length-data_reg'length-1; --total length minus data bytes;
        -- Accept every instruction
        if (inst_reg_val = '1' or init_reg = '1') then
          shifting     <= '1';
          read_n_write <= inst_rw and not init_reg; -- force write during init
          ncs_int      <= '0';
          sh_state     <= instruct;
        else
          shifting     <= '0';
          ncs_int      <= '1';
        end if;
      when instruct =>
        if (sh_counter = 0) then
          sh_counter <= data_reg'length-1;
          sh_state   <= data_io;
        else
          sh_counter <= sh_counter - 1;
        end if;
      when data_io =>
          sh_counter <= shift_reg'length-data_reg'length-1; --total length minus one data byte;
          shifting   <= '0';
          ncs_int    <= '1';
          if (read_n_write = '1') then
            sh_state <= data_valid;
          else
            sh_state <= idle;
          end if;
        else
        end if;
      when data_valid =>
        sh_state <= idle;
      when others =>
        sh_state <= idle;
    end case;
  end if;
end process;
busy <= '0' when (sh_state = idle and init_reg = '0') else '1';
