[DSP编程] CCS5.4下跑5509A串口例程的问题
2213|5
 楼主| wangch_sh 发表于 2014-12-23 16:41 | 显示全部楼层 |阅读模式
我在CCS3.3下跑TMS320VC5509A串口例程没问题,在CCS5.4下跑就有问题,串口发送,收不到数据。
程序如下:
/* DESCRIPTION:        */
/* This is an example for EMIF of C5509A        */
/* MODULE NAME... Mcbsp        */
/* FILENAME...... uart.c        */
/* DATE CREATED.. Mon 02/4/2004        */
/* COMPONENT.....        */
/* PREREQUISITS..        */
/* DESCRIPTION:        */
/* this example is that the software uart is done by Mcbsp */
#include <csl.h>
#include <csl_pll.h>
#include <csl_mcbsp.h>
#include <csl_irq.h>
#include <csl_timer.h>
#include <stdio.h>
//设置McBSP的PCR寄存器指针,用于读写其I/O端口
ioport unsigned int *PCR_1=(unsigned int *)0x2c12;
#define REG_PCR1 (*PCR_1)
/*锁相环的设置*/
PLL_Config  myConfig      = {
  0,    //IAI: the PLL locks using the same process that was underway
                //before the idle mode was entered
  1,    //IOB: If the PLL indicates a break in the phase lock,
                //it switches to its bypass mode and restarts the PLL phase-locking
                //sequence
  12,    //PLL multiply value; multiply 12 times
  0             //Divide by 1 PLL divide value; it can be either PLL divide value
                //(when PLL is enabled), or Bypass-mode divide value
                //(PLL in bypass mode, if PLL multiply value is set to 1)
/****************************设置Timer********************************/
/* 参考: TMS320VC5509 DSP Timers Reference Guide
         TMS320C55x Chip Support Library API Reference Guide (Rev. J)
                 HX-5509A 开发板使用手册                                     */
//---------Global data definition---------//
#define TIMER_CTRL    TIMER_TCR_RMK(\
                                                TIMER_TCR_IDLEEN_DEFAULT,    /* IDLEEN == 0 */ \
                                                TIMER_TCR_FUNC_OF(0),        /* FUNC   == 0 */ \
                                                TIMER_TCR_TLB_RESET,         /* TLB    == 1 */ \
                                                TIMER_TCR_SOFT_BRKPTNOW,     /* SOFT   == 0 */ \
                                                TIMER_TCR_FREE_WITHSOFT,     /* FREE   == 0 */ \
                                                TIMER_TCR_PWID_OF(0),        /* PWID   == 0 */ \
                                                TIMER_TCR_ARB_RESET,         /* ARB    == 1 */ \
                                                TIMER_TCR_TSS_START,         /* TSS    == 0 */ \
                                                TIMER_TCR_CP_PULSE,          /* CP     == 0 */ \
                                                TIMER_TCR_POLAR_LOW,         /* POLAR  == 0 */ \
                                                TIMER_TCR_DATOUT_0           /* DATOUT == 0 */ \
/* Create a TIMER configuration structure that can be passed */
/* to TIMER_config CSL function for initialization of Timer  */
/* control registers.                                        */
//产生1ms中断
TIMER_Config timCfg0 = {
   TIMER_CTRL,               /* TCR0 */
   749,                     /* PRD0 */
   0x0000                   /* PRSC */
/* Create a TIMER_Handle object for use with TIMER_open */
TIMER_Handle mhTimer0;
Uint16 eventId0;
Uint16 timer0_cnt = 0;
int old_intm;
Uint16 tim_val;
//---------Function prototypes---------
/* Reference start of interrupt vector table   */
/* This symbol is defined in file, vectors_timer1.s55 */
extern void VECSTART(void);
/* Function/ISR prototypes */
interrupt void timer0Isr(void);
/**************************McBSP1设置成GPIO*****************************/
/* 参考: TMS320C55x DSP Multichannel Buffered Serial Port (McBSP) Reference Guide
         HX-5509A 开发板使用手册
                 TMS320C55x Chip Support Library API Reference Guide (Rev. J)  */
MCBSP_Config Mcbsptest;
MCBSP_Config Mcbsp1Config = {
  MCBSP_SPCR1_RMK(
    MCBSP_SPCR1_DLB_OFF,                   /* DLB    = 0,禁止自闭环方式 */
    MCBSP_SPCR1_RJUST_LZF,                 /* RJUST  = 2 */
    MCBSP_SPCR1_CLKSTP_DISABLE,            /* CLKSTP = 0 */
    MCBSP_SPCR1_DXENA_ON,                  /* DXENA  = 1 */
    0,                                     /* ABIS   = 0 */
    MCBSP_SPCR1_RINTM_RRDY,                /* RINTM  = 0 */
    0,                                     /* RSYNCER = 0 */
    MCBSP_SPCR1_RRST_DISABLE               /* RRST   = 0 */
    MCBSP_SPCR2_RMK(
    MCBSP_SPCR2_FREE_NO,                   /* FREE   = 0 */
    MCBSP_SPCR2_SOFT_NO,                   /* SOFT   = 0 */
    MCBSP_SPCR2_FRST_FSG,                  /* FRST   = 0 */
    MCBSP_SPCR2_GRST_CLKG,                 /* GRST   = 0 */
    MCBSP_SPCR2_XINTM_XRDY,                /* XINTM  = 0 */
    0,                                     /* XSYNCER = N/A */
    MCBSP_SPCR2_XRST_DISABLE               /* XRST   = 0 */
   /*单数据相,接受数据长度为16位,每相2个数据*/
  MCBSP_RCR1_RMK(
          MCBSP_RCR1_RFRLEN1_OF(1),              /* RFRLEN1 = 1 */
          MCBSP_RCR1_RWDLEN1_16BIT               /* RWDLEN1 = 2 */
  MCBSP_RCR2_RMK(
    MCBSP_RCR2_RPHASE_SINGLE,              /* RPHASE  = 0 */
    MCBSP_RCR2_RFRLEN2_OF(0),              /* RFRLEN2 = 0 */
    MCBSP_RCR2_RWDLEN2_8BIT,               /* RWDLEN2 = 0 */
    MCBSP_RCR2_RCOMPAND_MSB,               /* RCOMPAND = 0 */
    MCBSP_RCR2_RFIG_YES,                   /* RFIG    = 0 */
    MCBSP_RCR2_RDATDLY_1BIT                /* RDATDLY = 1 */
   MCBSP_XCR1_RMK(
    MCBSP_XCR1_XFRLEN1_OF(1),              /* XFRLEN1 = 1 */
    MCBSP_XCR1_XWDLEN1_16BIT               /* XWDLEN1 = 2 */
MCBSP_XCR2_RMK(
    MCBSP_XCR2_XPHASE_SINGLE,              /* XPHASE  = 0 */
    MCBSP_XCR2_XFRLEN2_OF(0),              /* XFRLEN2 = 0 */
    MCBSP_XCR2_XWDLEN2_8BIT,               /* XWDLEN2 = 0 */
    MCBSP_XCR2_XCOMPAND_MSB,               /* XCOMPAND = 0 */
    MCBSP_XCR2_XFIG_YES,                   /* XFIG    = 0 */
    MCBSP_XCR2_XDATDLY_1BIT                /* XDATDLY = 1 */
MCBSP_SRGR1_DEFAULT,
MCBSP_SRGR2_DEFAULT,
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
   MCBSP_PCR_IDLEEN_RESET,                 /* IDLEEN   = 0   */
   MCBSP_PCR_XIOEN_GPIO,                   /* XIOEN    = 1   */
   MCBSP_PCR_RIOEN_GPIO,                   /* RIOEN    = 1   */
   MCBSP_PCR_FSXM_EXTERNAL,                /* FSXM     = 0   */
   MCBSP_PCR_FSRM_EXTERNAL,                /* FSRM     = 0   */
   MCBSP_PCR_CLKXM_INPUT,                  /* CLKXM    = 0   */
   MCBSP_PCR_CLKRM_INPUT,                  /* CLKRM    = 0   */
   MCBSP_PCR_SCLKME_NO,                    /* SCLKME   = 0   */
   MCBSP_PCR_DXSTAT_1,                     /* DXSTAT   = 1   */
   MCBSP_PCR_FSXP_ACTIVEHIGH,              /* FSXP     = 0   */
   MCBSP_PCR_FSRP_ACTIVEHIGH,              /* FSRP     = 1   */
   MCBSP_PCR_CLKXP_FALLING,                /* CLKXP    = 1   */
   MCBSP_PCR_CLKRP_RISING                  /* CLKRP    = 1   */
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
MCBSP_Handle hMcbsp;
Uint16 i,temp;
unsigned char timer0_cnten;
unsigned char uart_rec, uart_send, uart_recflag, uart_sendflag;
unsigned char uart_bitscan, uart_bitcnt, uart_recstart, uart_sendbitcnt;
unsigned char uart_bitsend, uart_bitsendcnt, uart_sendcnten, uart_sendend;
void delay(Uint32 k)
   while(k--);
void settimer(void)
        /* Set IVPH/IVPD to start of interrupt vector table */
        /*修改寄存器IVPH,IVPD,重新定义中断向量表*/
        IRQ_setVecs((Uint32)(&VECSTART));
        /* Temporarily disable all maskable interrupts */
    old_intm = IRQ_globalDisable();
    /* Open Timer 0, set registers to power on defaults */
    mhTimer0 = TIMER_open(TIMER_DEV0, TIMER_OPEN_RESET);
    /* Get Event Id associated with Timer 0, for use with */
    /* CSL interrupt enable functions.                    */
    eventId0 = TIMER_getEventId(mhTimer0);
    /* Clear any pending Timer interrupts */
    IRQ_clear(eventId0);
    /* Place interrupt service routine address at */
    /* associated vector location */
    IRQ_plug(eventId0,&timer0Isr);
    /* Write configuration structure values to Timer control regs */
    TIMER_config(mhTimer0, &timCfg0);
    /* Enable Timer interrupt */
    IRQ_enable(eventId0);
    /* Enable all maskable interrupts */
    IRQ_globalEnable();
    timer0_cnten = 0;
    uart_bitscan = 0;
    uart_bitcnt = 0;
        uart_recstart = 0;
        uart_recflag = 0;
        uart_sendflag = 0;
    /* Start Timer */
    TIMER_start(mhTimer0);
void main(void)
    /* Initialize CSL library - This is REQUIRED !!! */
    /*初始化CSL库*/
    CSL_init();
        /*设置系统的运行速度为144MHz*/
    PLL_config(&myConfig);
        /*初始化McBSP1*/
        hMcbsp = MCBSP_open(MCBSP_PORT1,MCBSP_OPEN_RESET);
        /*设置McBSP1*/
        MCBSP_config(hMcbsp,&Mcbsp1Config);
    MCBSP_getConfig(hMcbsp,&Mcbsptest);
        settimer();
/*************************以下程序实现软件Uart************************/
/* 参考:HX-5509A 开发板使用手册                                     */
        while(TRUE)
                if(uart_recflag==1)
                        uart_recflag = 0;
                        if(uart_sendflag==0)
                                uart_bitsendcnt = 0;
                                uart_sendend = 0;
                                uart_sendcnten = 0;
                                uart_bitsend = 0;
                                uart_send = uart_rec;
                                uart_sendflag = 1;
                                uart_sendbitcnt = 0;
        temp = REG_PCR1;
        //Send
        if(uart_sendflag==1)
                if(uart_sendcnten==0)
                        REG_PCR1 &= 0xffdf;
                        uart_bitsend = 1;
                        uart_sendcnten = 1;
                if(uart_sendcnten==1)
                        uart_bitsendcnt++;
                        if(uart_bitsendcnt==10)
                                uart_sendbitcnt++;
                                if(uart_sendend==1)
                                        uart_sendflag = 0;
                                else
                                        if(uart_sendbitcnt<9)
                                                if((uart_send & uart_bitsend)==0)
                                                        REG_PCR1 &= 0xffdf;
                                                else
                                                        REG_PCR1 |= 0x0020;
                                                uart_bitsend <<= 1;
                                        else
                                                REG_PCR1 |= 0x0020;
                        uart_sendflag = 0;
        //Receive
        if((uart_bitcnt==0)&&(uart_recstart==0))
                if((temp&0x0010)==0)
                        timer0_cnt = 0;
                        timer0_cnten = 1;
                        uart_bitscan = 0;
                        uart_rec = 0;
                        uart_recstart = 1;
        if(timer0_cnten==1)
                timer0_cnt++;
                if((temp&0x0010)!=0)
                        uart_bitscan++;
                if(timer0_cnt==10)
                        timer0_cnt = 0;
                        if(uart_bitscan>5)
                                switch(uart_bitcnt)
                                        case 0:  uart_rec = 0;
                                                 timer0_cnten = 0;
                                                         uart_recstart = 0;
                                                         break;
                                        case 1:  uart_bitcnt++;
                                                         uart_rec |= 0x01;
                                                         break;
                                        case 2:  uart_bitcnt++;
                                                         uart_rec |= 0x02;
                                                         break;
                                        case 3:  uart_bitcnt++;
                                                         uart_rec |= 0x04;
                                                         break;
                                        case 4:  uart_bitcnt++;
                                                         uart_rec |= 0x08;
                                                         break;
                                        case 5:  uart_bitcnt++;
                                                         uart_rec |= 0x10;
                                                         break;
                                        case 6:  uart_bitcnt++;
                                                         uart_rec |= 0x20;
                                                         break;
                                        case 7:  uart_bitcnt++;
                                                         uart_rec |= 0x40;
                                                         break;
                                        case 8:  uart_bitcnt++;
                                                         uart_rec |= 0x80;
                                                         break;
                                        case 9:  uart_bitcnt = 0;
                                                         timer0_cnten = 0;
                                                         uart_recflag = 1;
                                                         uart_recstart = 0;
                                                         break;
                                        default: break;
                        else
                            uart_bitcnt++;
                                if(uart_bitcnt>9)
                                        uart_bitcnt = 0;
                                        timer0_cnten = 0;
                        uart_bitscan = 0;
* End of uart.c
请高手指教,谢谢!
 楼主| wangch_sh 发表于 2014-12-23 16:50 | 显示全部楼层
我的配置如下:
 楼主| wangch_sh 发表于 2014-12-24 11:00 | 显示全部楼层
高手支招啊!
 楼主| wangch_sh 发表于 2014-12-24 16:58 | 显示全部楼层
现在又出现新的现象。我运行程序以后,只要一从串口调试助手发送数据,CCS的界面就变成这样:
 楼主| wangch_sh 发表于 2014-12-24 17:49 | 显示全部楼层
现在我观察变量,应是0-9的,可是显示成一个点。
zhangmangui 发表于 2014-12-25 21:40 | 显示全部楼层
搞不到 啊    看过这个代码   用IO模拟的吧   一次只能接收一个字节
先看看自发自收是不是通的
个人签名:为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
318
