- #!/usr/bin/python
- import Adafruit_BBIO.GPIO as GPIO
- import time
- def getDistanceCM():
- GPIO_TRIGGER = 'P8_12';
- GPIO_ECHO = 'P8_11';
- GPIO.setup(GPIO_TRIGGER,GPIO.OUT);
- GPIO.setup(GPIO_ECHO,GPIO.IN);
- GPIO_HIGH = GPIO.HIGH;
- GPIO_LOW = GPIO.LOW;
- GPIO.output(GPIO_TRIGGER, GPIO_LOW);
- time.sleep(0.00001);
- GPIO.output(GPIO_TRIGGER, GPIO_HIGH);
- while GPIO.input(GPIO_ECHO)==GPIO_LOW:
- pass;
- start = time.time();
- while GPIO.input(GPIO_ECHO)==GPIO_HIGH:
- pass;
- stop = time.time();
- elapsed = stop-start;
- distance = elapsed * 34000;
- distance = distance / 2;
- GPIO.cleanup();
- return distance;
- if __name__ == '__main__':
- while True:
- distance = getDistanceCM();
- time.sleep(0.5);
- print 'Distance: %f cm' % distance;
实验结果:
【舵机测试部分】
舵机控制用Python库的PWM实现,控制起来也挺简单的。
舵机的基准信号都是周期为20ms,宽度为1.5ms。这个基准信号定义的位置为中间位置。舵机有最大转动角度,中间位置的定义就是从这个位置到最大角度与最小角度的量完全一样。
Python库中的PWM函数,一条语句就能控制舵机
PWM.start(channel,duty, freq=2000, polarity=0)
程序:
舵机信号引脚接P8_13
- #!/usr/bin/python
- import Adafruit_BBIO.PWM as PWM
- import time
- def servo_middle():
- PWM.start("P8_13", 7.5, 50, 0)
- def servo_left():
- PWM.start("P8_13", 10, 50, 0)
- def servo_right():
- PWM.start("P8_13", 5, 50, 0)
- while True:
- servo_left()
- time.sleep(1)
- servo_right()
- time.sleep(1)
- servo_middle()
- time.sleep(1)
实现舵机左转、右转和处于中间位置
【电机驱动部分】
主要通过1个L298N模块驱动4个减速电机,左边两个电机接一起,接L298N模块的OUT3、OUT4,右边两个电机接一起,接L298N模块的OUT1、OUT2。
IN1接P8_7
IN2接P8_8
IN3接P9_11
IN4接P9_12
程序:
- #!/usr/bin/python
- import time
- RIGHT_IN1 = 'P8_7'
- RIGHT_IN2 = 'P8_8'
- LEFT_IN3 = 'P9_11'
- LEFT_IN4 = 'P9_12'
- GPIO.setup(RIGHT_IN1, GPIO.OUT)
- GPIO.setup(RIGHT_IN2, GPIO.OUT)
- GPIO.setup(LEFT_IN3, GPIO.OUT)
- GPIO.setup(LEFT_IN4, GPIO.OUT)
- def front():
- GPIO.output(RIGHT_IN1, False)
- GPIO.output(RIGHT_IN2, True)
- GPIO.output(LEFT_IN3, False)
- GPIO.output(LEFT_IN4, True)
- def back():
- GPIO.output(RIGHT_IN1, True)
- GPIO.output(RIGHT_IN2, False)
- GPIO.output(LEFT_IN3, True)
- GPIO.output(LEFT_IN4, False)
- def stop():
- def left():
- def right():
- while True:
- front()
- time.sleep(5)
- back()
- time.sleep(5)
- left()
- time.sleep(5)
- right()
- time.sleep(5)
- stop()
- time.sleep(5)
实现小车前进、后退、左转弯、右转弯和停止
【综合测试】
程序仍然存在BUG,刚开始正常运行,一段时间后感觉程序就乱了,有待进一步解决,还请各位朋友指点一下。:L:L:L
程序:
- #!/usr/bin/python
- import time
- def front():
- print 'front'
- def back():
- print 'back'
- def stop():
- print 'stop'
- def left():
- print 'left'
- def right():
- print 'right'
- pass;
- pass;
- GPIO.cleanup();
- return distance;
- def servo_left():
- servo_middle()
- while True:
- time.sleep(0.5)
- if distance > 50:
- front()
- time.sleep(0.5)
- stop()
- elif distance > 20:
- front()
- time.sleep(0.2)
- stop()
- else:
- stop()
- servo_left()
- distance_l = getDistanceCM()
- time.sleep(0.5)
- print 'Distance_l: %f cm' % distance_l
- servo_right()
- distance_r = getDistanceCM()
- time.sleep(0.5)
- print 'Distance_r: %f cm' % distance_r
- servo_middle()
- if distance_l < 15.0 and distance_r < 15.0:
- back()
- time.sleep(0.3)
- stop()
- elif distance_l > distance_r:
- left()
- time.sleep(0.2)
- stop()
- else:
- right()
- time.sleep(0.2)
- stop()
RIGHT_IN1 = 'P8_7'
RIGHT_IN2 = 'P8_8'
LEFT_IN3 = 'P9_11'
LEFT_IN4 = 'P9_12'
这几句定义引脚输出的语句,本来是放在程序的开头执行,程序结合起来感觉语句好像“失效”了,电机不转,然后就在front()、back()、left()、right()等函数中都加上了,电机终于能转了,可能是对Python编程不够了解。
