[i.MX]
Failed building m4
1145|0
空戈|  楼主 | 2015-4-4 20:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
make[3]: *** [clean-temp.o] Error 1
make[3]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16/lib'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16/lib'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16'
make: *** [all] Error 2
error: Bad exit status from /home/zyy/myzr/imx6/L3.0.35_4.1.0_130816_source/source/ltib/tmp/rpm-tmp.60379 (%build)
RPM build errors:
Build time for m4: 33 seconds
Failed building m4
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Sat Apr  4 19:40:09 2015
Ended:   Sat Apr  4 19:40:43 2015
Elapsed: 34 seconds
实在不知道怎么办了,求解~~
