/root.big/dw/tgz/lsof_4.78/lsof_4.78_src $ ./lsof COMMAND PID USER FD TYPE DEVICE SIZE NODE NAME init 1 root cwd DIR 31,2 0 1 / init 1 root rtd DIR 31,2 0 1 / init 1 root txt REG 31,2 857680 26 /bin/busybox init 1 root mem REG 31,2 137585 1439 /lib/ld-2.5.so init 1 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so init 1 root mem REG 31,2 743776 1448 /lib/libm-2.5.so init 1 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 init 1 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so init 1 root 0u CHR 5,1 107 /dev/console init 1 root 1u CHR 5,1 107 /dev/console init 1 root 2u CHR 5,1 107 /dev/console ksoftirqd 2 root cwd DIR 31,2 0 1 / ksoftirqd 2 root rtd DIR 31,2 0 1 / events/0 3 root cwd DIR 31,2 0 1 / events/0 3 root rtd DIR 31,2 0 1 / khelper 4 root cwd DIR 31,2 0 1 / khelper 4 root rtd DIR 31,2 0 1 / kthread 5 root cwd DIR 31,2 0 1 / kthread 5 root rtd DIR 31,2 0 1 / kblockd/0 28 root cwd DIR 31,2 0 1 / kblockd/0 28 root rtd DIR 31,2 0 1 / pdflush 41 root cwd DIR 31,2 0 1 / pdflush 41 root rtd DIR 31,2 0 1 / kswapd0 42 root cwd DIR 31,2 0 1 / kswapd0 42 root rtd DIR 31,2 0 1 / aio/0 43 root cwd DIR 31,2 0 1 / aio/0 43 root rtd DIR 31,2 0 1 / busybox 652 root cwd DIR 31,2 0 1 / busybox 652 root rtd DIR 31,2 0 1 / busybox 652 root txt REG 31,2 857680 26 /bin/busybox busybox 652 root mem REG 31,2 137585 1439 /lib/ld-2.5.so busybox 652 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so busybox 652 root mem REG 31,2 743776 1448 /lib/libm-2.5.so busybox 652 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 busybox 652 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so busybox 652 root 0u CHR 1,3 1014 /dev/null busybox 652 root 1u CHR 1,3 1014 /dev/null busybox 652 root 2u CHR 1,3 1014 /dev/null busybox 652 root 3u IPv4 690 TCP *:telnet (LISTEN)
busybox 652 root 4u IPv4 78714 TCP wangkj:telnet->192.168.8.104:descent3 (ESTABLISHED) busybox 652 root 5u CHR 2,0 1026 /dev/ptyp0 busybox 652 root 6u IPv4 78917 TCP wangkj:telnet->192.168.8.104:lv-not (ESTABLISHED) busybox 652 root 7u CHR 2,1 1027 /dev/ptyp1 jffs2_gcd 660 root cwd DIR 31,2 0 1 / jffs2_gcd 660 root rtd DIR 31,2 0 1 / kmmcd 688 root cwd DIR 31,2 0 1 / kmmcd 688 root rtd DIR 31,2 0 1 / mmcqd 706 root cwd DIR 31,2 0 1 / mmcqd 706 root rtd DIR 31,2 0 1 / khubd 723 root cwd DIR 31,2 0 1 / khubd 723 root rtd DIR 31,2 0 1 / vsftpd 807 root cwd DIR 31,3 0 1 /opt vsftpd 807 root rtd DIR 31,2 0 1 / vsftpd 807 root txt REG 254,2 115379 350 /root.big/usr/sbin/vsftpd vsftpd 807 root mem REG 31,2 137585 1439 /lib/ld-2.5.so vsftpd 807 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so vsftpd 807 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 vsftpd 807 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so vsftpd 807 root 0u CHR 1,3 1014 /dev/null vsftpd 807 root 1u CHR 1,3 1014 /dev/null vsftpd 807 root 2u CHR 1,3 1014 /dev/null vsftpd 807 root 3u IPv4 908 TCP *:ftp (LISTEN) mysqld 808 mysql cwd DIR 254,2 4096 697659 /root.big/var/mysql mysqld 808 mysql rtd DIR 31,2 0 1 / mysqld 808 mysql txt REG 254,2 2587780 384 /root.big/usr/libexec/mysqld mysqld 808 mysql mem REG 31,2 137585 1439 /lib/ld-2.5.so mysqld 808 mysql mem REG 254,2 70452 444 /root.big/usr/lib/libz.so.1.2.3 mysqld 808 mysql mem REG 254,2 10032 519172 /root.big/lib/libdl-2.5.so mysqld 808 mysql mem REG 254,2 83272 519195 /root.big/lib/libpthread-2.5.so mysqld 808 mysql mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so mysqld 808 mysql mem REG 254,2 72284 519185 /root.big/lib/libnsl-2.5.so mysqld 808 mysql mem REG 254,2 783692 447 /root.big/usr/lib/libstdc++.so.6.0.8 mysqld 808 mysql mem REG 31,2 743776 1448 /lib/libm-2.5.so mysqld 808 mysql mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 mysqld 808 mysql mem REG 31,2 1416028 1441 /lib/libc-2.5.so mysqld 808 mysql mem REG 254,2 38772 519187 /root.big/lib/libnss_files-2.5.so mysqld 808 mysql 0r CHR 1,3 1014 /dev/null mysqld 808 mysql 1u CHR 5,1 107 /dev/console mysqld 808 mysql 2u CHR 5,1 107 /dev/console mysqld 808 mysql 3u unix 0xc1fa6de0 961 /tmp/mysql.sock mysqld 808 mysql 4u REG 254,2 1024 697777 /root.big/var/mysql/mysql/host.MYI mysqld 808 mysql 5u REG 254,2 0 697778 /root.big/var/mysql/mysql/host.MYD mysqld 808 mysql 6u REG 254,2 2048 697780 /root.big/var/mysql/mysql/user.MYI mysqld 808 mysql 7u REG 254,2 216 697781 /root.big/var/mysql/mysql/user.MYD mysqld 808 mysql 8u REG 254,2 4096 697774 /root.big/var/mysql/mysql/db.MYI mysqld 808 mysql 9u REG 254,2 866 697775 /root.big/var/mysql/mysql/db.MYD mysqld 808 mysql 10u REG 254,2 1024 697786 /root.big/var/mysql/mysql/tables_priv.MYI mysqld 808 mysql 11u REG 254,2 0 697787 /root.big/var/mysql/mysql/tables_priv.MYD mysqld 808 mysql 12u REG 254,2 1024 697789 /root.big/var/mysql/mysql/columns_priv.MYI mysqld 808 mysql 13u REG 254,2 0 697790 /root.big/var/mysql/mysql/columns_priv.MYD mysqld 808 mysql 15u REG 254,2 2048 698013 /root.big/var/mysql/discuz/cdb_stats.MYI mysqld 808 mysql 16u REG 254,2 4290 698014 /root.big/var/mysql/discuz/cdb_stats.MYD mysqld 808 mysql 17u REG 254,2 3072 697874 /root.big/var/mysql/discuz/cdb_crons.MYI mysqld 808 mysql 18u REG 254,2 5512 697875 /root.big/var/mysql/discuz/cdb_crons.MYD mysqld 808 mysql 19u REG 254,2 4096 697892 /root.big/var/mysql/discuz/cdb_forums.MYI mysqld 808 mysql 20u REG 254,2 2080 697893 /root.big/var/mysql/discuz/cdb_forums.MYD mysqld 808 mysql 21u REG 254,2 7168 698004 /root.big/var/mysql/discuz/cdb_settings.MYI mysqld 808 mysql 22u REG 254,2 6832 698005 /root.big/var/mysql/discuz/cdb_settings.MYD mysqld 808 mysql 23u REG 254,2 14336 698016 /root.big/var/mysql/discuz/cdb_statvars.MYI mysqld 808 mysql 24u REG 254,2 28288 698017 /root.big/var/mysql/discuz/cdb_statvars.MYD mysqld 808 mysql 25u REG 254,2 8192 697967 /root.big/var/mysql/discuz/cdb_posts.MYI mysqld 808 mysql 26u REG 254,2 59056 697968 /root.big/var/mysql/discuz/cdb_posts.MYD mysqld 808 mysql 27u REG 254,2 4096 697916 /root.big/var/mysql/discuz/cdb_members.MYI mysqld 808 mysql 28u REG 254,2 19413 697917 /root.big/var/mysql/discuz/cdb_members.MYD mysqld 808 mysql 29u REG 254,2 1024 697922 /root.big/var/mysql/discuz/cdb_moderators.MYI mysqld 808 mysql 30u REG 254,2 0 697923 /root.big/var/mysql/discuz/cdb_moderators.MYD mysqld 808 mysql 31u REG 254,2 2048 697937 /root.big/var/mysql/discuz/cdb_onlinetime.MYI mysqld 808 mysql 32u REG 254,2 117 697938 /root.big/var/mysql/discuz/cdb_onlinetime.MYD mysqld 808 mysql 33u REG 254,2 1024 697925 /root.big/var/mysql/discuz/cdb_modworks.MYI mysqld 808 mysql 34u REG 254,2 0 697926 /root.big/var/mysql/discuz/cdb_modworks.MYD mysqld 808 mysql 35u REG 254,2 1024 697847 /root.big/var/mysql/discuz/cdb_announcements.MYI mysqld 808 mysql 36u REG 254,2 0 697848 /root.big/var/mysql/discuz/cdb_announcements.MYD mysqld 808 mysql 37u REG 254,2 4096 697904 /root.big/var/mysql/discuz/cdb_magics.MYI mysqld 808 mysql 38u REG 254,2 1036 697905 /root.big/var/mysql/discuz/cdb_magics.MYD mysqld 808 mysql 39u REG 254,2 6144 698031 /root.big/var/mysql/discuz/cdb_threads.MYI mysqld 808 mysql 40u REG 254,2 9802 698032 /root.big/var/mysql/discuz/cdb_threads.MYD mysqld 808 mysql 41u REG 254,2 2048 697886 /root.big/var/mysql/discuz/cdb_forumfields.MYI mysqld 808 mysql 42u REG 254,2 80 697887 /root.big/var/mysql/discuz/cdb_forumfields.MYD mysqld 808 mysql 43u REG 254,2 2048 697910 /root.big/var/mysql/discuz/cdb_memberfields.MYI mysqld 808 mysql 44u REG 254,2 844 697911 /root.big/var/mysql/discuz/cdb_memberfields.MYD mysqld 808 mysql 45u REG 254,2 1024 697979 /root.big/var/mysql/discuz/cdb_pushedthreads.MYI mysqld 808 mysql 46u REG 254,2 0 697980 /root.big/var/mysql/discuz/cdb_pushedthreads.MYD mysqld 808 mysql 47u REG 254,2 1024 698025 /root.big/var/mysql/discuz/cdb_subscriptions.MYI mysqld 808 mysql 48u REG 254,2 0 698026 /root.big/var/mysql/discuz/cdb_subscriptions.MYD mysqld 808 mysql 49u REG 254,2 1024 698034 /root.big/var/mysql/discuz/cdb_threadsmod.MYI mysqld 808 mysql 50u REG 254,2 0 698035 /root.big/var/mysql/discuz/cdb_threadsmod.MYD mysqld 808 mysql 51u REG 254,2 1024 697844 /root.big/var/mysql/discuz/cdb_advertisements.MYI mysqld 808 mysql 52u REG 254,2 0 697845 /root.big/var/mysql/discuz/cdb_advertisements.MYD mysqld 808 mysql 53u REG 254,2 1024 697895 /root.big/var/mysql/discuz/cdb_itempool.MYI mysqld 808 mysql 54u REG 254,2 0 697896 /root.big/var/mysql/discuz/cdb_itempool.MYD mysqld 808 mysql 55u REG 254,2 3072 697880 /root.big/var/mysql/discuz/cdb_faqs.MYI mysqld 808 mysql 56u REG 254,2 20072 697881 /root.big/var/mysql/discuz/cdb_faqs.MYD mysqld 808 mysql 57u REG 254,2 3072 698046 /root.big/var/mysql/discuz/cdb_usergroups.MYI mysqld 808 mysql 58u REG 254,2 17160 698047 /root.big/var/mysql/discuz/cdb_usergroups.MYD mysqld 808 mysql 59u REG 254,2 2048 698019 /root.big/var/mysql/discuz/cdb_styles.MYI mysqld 808 mysql 60u REG 254,2 24 698020 /root.big/var/mysql/discuz/cdb_styles.MYD mysqld 808 mysql 61u REG 254,2 3072 697997 /root.big/var/mysql/discuz/cdb_rsscaches.MYI mysqld 808 mysql 62u REG 254,2 31564 697998 /root.big/var/mysql/discuz/cdb_rsscaches.MYD mysqld 808 mysql 63u REG 254,2 2048 697919 /root.big/var/mysql/discuz/cdb_memberspaces.MYI mysqld 808 mysql 64u REG 254,2 26055 697920 /root.big/var/mysql/discuz/cdb_memberspaces.MYD mysqld 808 mysql 65u REG 254,2 5120 698010 /root.big/var/mysql/discuz/cdb_spacecaches.MYI mysqld 808 mysql 66u REG 254,2 18444 698011 /root.big/var/mysql/discuz/cdb_spacecaches.MYD mysqld 808 mysql 67u REG 254,2 3072 697931 /root.big/var/mysql/discuz/cdb_mythreads.MYI mysqld 808 mysql 68u REG 254,2 242 697932 /root.big/var/mysql/discuz/cdb_mythreads.MYD mysqld 808 mysql 69u REG 254,2 3072 697928 /root.big/var/mysql/discuz/cdb_myposts.MYI mysqld 808 mysql 70u REG 254,2 425 697929 /root.big/var/mysql/discuz/cdb_myposts.MYD mysqld 808 mysql 71u REG 254,2 1024 697883 /root.big/var/mysql/discuz/cdb_favorites.MYI mysqld 808 mysql 72u REG 254,2 0 697884 /root.big/var/mysql/discuz/cdb_favorites.MYD sh 809 root cwd DIR 31,3 0 1 /opt sh 809 root rtd DIR 31,2 0 1 / sh 809 root txt REG 31,2 857680 26 /bin/busybox sh 809 root mem REG 31,2 137585 1439 /lib/ld-2.5.so sh 809 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so sh 809 root mem REG 31,2 743776 1448 /lib/libm-2.5.so sh 809 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 sh 809 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so sh 809 root 0r CHR 1,3 1014 /dev/null sh 809 root 1u CHR 5,1 107 /dev/console sh 809 root 2u CHR 5,1 107 /dev/console sh 809 root 10r REG 31,3 894 1702 /opt/1.sh sshd 819 root cwd DIR 31,2 0 1 / sshd 819 root rtd DIR 31,2 0 1 / sshd 819 root txt REG 254,2 302120 351 /root.big/usr/sbin/sshd sshd 819 root mem REG 31,2 137585 1439 /lib/ld-2.5.so sshd 819 root mem REG 31,2 75812 1456 /lib/libresolv-2.5.so sshd 819 root mem REG 254,2 994032 439 /root.big/usr/lib/libcrypto.so.0.9.7 sshd 819 root mem REG 254,2 9936 519201 /root.big/lib/libutil-2.5.so sshd 819 root mem REG 254,2 70452 444 /root.big/usr/lib/libz.so.1.2.3 sshd 819 root mem REG 254,2 72284 519185 /root.big/lib/libnsl-2.5.so sshd 819 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so sshd 819 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 sshd 819 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so sshd 819 root mem REG 254,2 10032 519172 /root.big/lib/libdl-2.5.so sshd 819 root mem REG 254,2 38772 519187 /root.big/lib/libnss_files-2.5.so sshd 819 root 0u CHR 1,3 1014 /dev/null sshd 819 root 1u CHR 1,3 1014 /dev/null sshd 819 root 2u CHR 1,3 1014 /dev/null sshd 819 root 3u IPv4 936 TCP *:ssh (LISTEN) jffs2_gcd 827 root cwd DIR 31,2 0 1 / jffs2_gcd 827 root rtd DIR 31,2 0 1 / httpd 843 root cwd DIR 31,2 0 1 / httpd 843 root rtd DIR 31,2 0 1 / httpd 843 root txt REG 254,2 650208 363 /root.big/usr/sbin/httpd httpd 843 root mem REG 31,2 137585 1439 /lib/ld-2.5.so httpd 843 root mem REG 254,2 183084 438 /root.big/usr/lib/libssl.so.0.9.7 httpd 843 root mem REG 254,2 994032 439 /root.big/usr/lib/libcrypto.so.0.9.7 httpd 843 root mem REG 31,2 743776 1448 /lib/libm-2.5.so httpd 843 root mem REG 254,2 79224 396 /root.big/usr/lib/libaprutil-1.so.0.2.7 httpd 843 root mem REG 254,2 118216 441 /root.big/usr/lib/libexpat.so.1.5.0 httpd 843 root mem REG 254,2 135320 393 /root.big/usr/lib/libapr-1.so.0.2.7 httpd 843 root mem REG 254,2 35528 519189 /root.big/lib/librt-2.5.so httpd 843 root mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so httpd 843 root mem REG 254,2 10032 519172 /root.big/lib/libdl-2.5.so httpd 843 root mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 httpd 843 root mem REG 31,2 1416028 1441 /lib/libc-2.5.so httpd 843 root mem REG 254,2 83272 519195 /root.big/lib/libpthread-2.5.so httpd 843 root mem REG 254,2 38772 519187 /root.big/lib/libnss_files-2.5.so httpd 843 root DEL REG 0,7 966 /dev/zero httpd 843 root 0r CHR 1,3 1014 /dev/null httpd 843 root 1w CHR 1,3 1014 /dev/null httpd 843 root 2w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 843 root 3u IPv4 942 TCP *:http (LISTEN) httpd 843 root 4r FIFO 0,5 964 pipe httpd 843 root 5w FIFO 0,5 964 pipe httpd 843 root 6w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 843 root 7w REG 254,2 17685290 697657 /root.big/var/apache2/logs/access_log httpd 846 daemon cwd DIR 31,2 0 1 / httpd 846 daemon rtd DIR 31,2 0 1 / httpd 846 daemon txt REG 254,2 650208 363 /root.big/usr/sbin/httpd httpd 846 daemon mem REG 31,2 137585 1439 /lib/ld-2.5.so httpd 846 daemon mem REG 254,2 183084 438 /root.big/usr/lib/libssl.so.0.9.7 httpd 846 daemon mem REG 254,2 994032 439 /root.big/usr/lib/libcrypto.so.0.9.7 httpd 846 daemon mem REG 31,2 743776 1448 /lib/libm-2.5.so httpd 846 daemon mem REG 254,2 79224 396 /root.big/usr/lib/libaprutil-1.so.0.2.7 httpd 846 daemon mem REG 254,2 118216 441 /root.big/usr/lib/libexpat.so.1.5.0 httpd 846 daemon mem REG 254,2 135320 393 /root.big/usr/lib/libapr-1.so.0.2.7 httpd 846 daemon mem REG 254,2 35528 519189 /root.big/lib/librt-2.5.so httpd 846 daemon mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so httpd 846 daemon mem REG 254,2 10032 519172 /root.big/lib/libdl-2.5.so httpd 846 daemon mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 httpd 846 daemon mem REG 31,2 1416028 1441 /lib/libc-2.5.so httpd 846 daemon mem REG 254,2 83272 519195 /root.big/lib/libpthread-2.5.so httpd 846 daemon mem REG 254,2 38772 519187 /root.big/lib/libnss_files-2.5.so httpd 846 daemon DEL REG 0,7 966 /dev/zero httpd 846 daemon 0r CHR 1,3 1014 /dev/null httpd 846 daemon 1w CHR 1,3 1014 /dev/null httpd 846 daemon 2w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 846 daemon 3u IPv4 942 TCP *:http (LISTEN) httpd 846 daemon 4r FIFO 0,5 964 pipe httpd 846 daemon 5w FIFO 0,5 964 pipe httpd 846 daemon 6w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 846 daemon 7w REG 254,2 17685290 697657 /root.big/var/apache2/logs/access_log httpd 3667 daemon cwd DIR 31,2 0 1 / httpd 3667 daemon rtd DIR 31,2 0 1 / httpd 3667 daemon txt REG 254,2 650208 363 /root.big/usr/sbin/httpd httpd 3667 daemon mem REG 31,2 137585 1439 /lib/ld-2.5.so httpd 3667 daemon mem REG 254,2 183084 438 /root.big/usr/lib/libssl.so.0.9.7 httpd 3667 daemon mem REG 254,2 994032 439 /root.big/usr/lib/libcrypto.so.0.9.7 httpd 3667 daemon mem REG 31,2 743776 1448 /lib/libm-2.5.so httpd 3667 daemon mem REG 254,2 79224 396 /root.big/usr/lib/libaprutil-1.so.0.2.7 httpd 3667 daemon mem REG 254,2 118216 441 /root.big/usr/lib/libexpat.so.1.5.0 httpd 3667 daemon mem REG 254,2 135320 393 /root.big/usr/lib/libapr-1.so.0.2.7 httpd 3667 daemon mem REG 254,2 35528 519189 /root.big/lib/librt-2.5.so httpd 3667 daemon mem REG 31,2 28478 1443 /lib/libcrypt-2.5.so httpd 3667 daemon mem REG 254,2 10032 519172 /root.big/lib/libdl-2.5.so httpd 3667 daemon mem REG 31,2 66294 1447 /lib/libgcc_s.so.1 httpd 3667 daemon mem REG 31,2 1416028 1441 /lib/libc-2.5.so httpd 3667 daemon mem REG 254,2 83272 519195 /root.big/lib/libpthread-2.5.so httpd 3667 daemon mem REG 254,2 38772 519187 /root.big/lib/libnss_files-2.5.so httpd 3667 daemon DEL REG 0,7 966 /dev/zero httpd 3667 daemon 0r CHR 1,3 1014 /dev/null httpd 3667 daemon 1w CHR 1,3 1014 /dev/null httpd 3667 daemon 2w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 3667 daemon 3u IPv4 942 TCP *:http (LISTEN) httpd 3667 daemon 4r FIFO 0,5 964 pipe httpd 3667 daemon 5w FIFO 0,5 964 pipe httpd 3667 daemon 6w REG 254,2 2131797 697656 /root.big/var/apache2/logs/error_log httpd 3667 daemon 7w REG 254,2 17685290 697657 /root.big/var/apache2/logs/access_log httpd 3695 daemon cwd DIR 31,2 0 1 / httpd & |
