行为级仿真和布线后仿真的问题
4508|2
 楼主| 陈文 发表于 2007-9-19 09:30 | 显示全部楼层 |阅读模式
我的行为级仿真能通过,但在MODELSIM里面提示了如下错误:&nbsp;Loading&nbsp;work.Rxcrctest_v<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'xilinxcorelib_ver'&nbsp;at&nbsp;&quot;xilinxcorelib_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'unisims_ver'&nbsp;at&nbsp;&quot;unisims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.Rx_CRC<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'xilinxcorelib_ver'&nbsp;at&nbsp;&quot;xilinxcorelib_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'unisims_ver'&nbsp;at&nbsp;&quot;unisims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.recv<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'xilinxcorelib_ver'&nbsp;at&nbsp;&quot;xilinxcorelib_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'unisims_ver'&nbsp;at&nbsp;&quot;unisims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.CRC_chk<br />#&nbsp;**&nbsp;Warning:&nbsp;(vsim-3009)&nbsp;[TSCALE]&nbsp;-&nbsp;Module&nbsp;'CRC_chk'&nbsp;does&nbsp;not&nbsp;have&nbsp;a&nbsp;`timescale&nbsp;directive&nbsp;in&nbsp;effect,&nbsp;but&nbsp;previous&nbsp;modules&nbsp;do.<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Region:&nbsp;/Rxcrctest_v/uut/My_crcchk<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'xilinxcorelib_ver'&nbsp;at&nbsp;&quot;xilinxcorelib_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'unisims_ver'&nbsp;at&nbsp;&quot;unisims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.clk_Div<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'xilinxcorelib_ver'&nbsp;at&nbsp;&quot;xilinxcorelib_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'unisims_ver'&nbsp;at&nbsp;&quot;unisims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.clk_DataReady<br />#&nbsp;Loading&nbsp;work.glbl<br /><br /><br />但是综合后仿真就不行了,提示错误如下:#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;Loading&nbsp;work.Rx_CRC<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-3033)&nbsp;Rx_CRC_translate.v(257):&nbsp;Instantiation&nbsp;of&nbsp;'X_FF'&nbsp;failed.&nbsp;The&nbsp;design&nbsp;unit&nbsp;was&nbsp;not&nbsp;found.<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Region:&nbsp;/Rxcrctest_v/uut<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Searched&nbsp;libraries:<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;work<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-3033)&nbsp;Rx_CRC_translate.v(266):&nbsp;Instantiation&nbsp;of&nbsp;'X_FF'&nbsp;failed.&nbsp;The&nbsp;design&nbsp;unit&nbsp;was&nbsp;not&nbsp;found.<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Region:&nbsp;/Rxcrctest_v/uut<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Searched&nbsp;libraries:<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br />#&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory.&nbsp;(errno&nbsp;=&nbsp;ENOENT)<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;work<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-19)&nbsp;Failed&nbsp;to&nbsp;access&nbsp;library&nbsp;'simprims_ver'&nbsp;at&nbsp;&quot;simprims_ver&quot;.<br /><br />………………<br />后面还有很多,波形出不来。<br /><br />请问是仿真器设置的问题还是程序的问题呢?我的程序综合的时候连警告都没有。谢谢~<br />&nbsp;&nbsp;
hb_3l 发表于 2010-3-12 20:38 | 显示全部楼层
SSsnail 发表于 2010-3-13 16:59 | 显示全部楼层
编译库没有加载
