发帖 求救,移植qt4.3.0 到 2440板,兄弟想将qt4.3.0 到 2440板上 1 用x86的 gcc 编译通过 , qvfb 和 ./hello 都OK 2 安装arm-linux-gcc 3.4.1 后 ./configure -embedded arm -xplatform qws/linux-arm-g++ -depths 4,8,12,16 -no-qt3support -------------OK 3 make ----OK 4 sudo make install 后有错误:
make[3]: Entering directory `/home/eric/reserch/qt/debugx86build/examples/dialogs/extension' cp -f "extension" "/usr/local/Trolltech/QtopiaCore-4.3.0-arm/examples/dialogs/extension/extension" arm-linux-strip "/usr/local/Trolltech/QtopiaCore-4.3.0-arm/examples/dialogs/extension/extension" /bin/sh: arm-linux-strip: not found make[3]: [install_target] 错误 127 (忽略) 有错误 /bin/sh: arm-linux-strip: not found 但是我的 执行 ls /usr/local/arm/3.4.1/bin/arm-linux-strip 后 eric@eric-laptop:~$ ls /usr/local/arm/3.4.1/bin/arm-linux-strip /usr/local/arm/3.4.1/bin/arm-linux-strip eric@eric-laptop:~$
我的 arm-linux-strip是有的哦 奇怪哦?
