//h文件中<br /><br />class LZX_E2<br />{<br /> private:<br /> void at24xx_start(void);<br /> void edelay(unsigned int);<br /> void at24xx_stop(void);<br /> void at24xx_lo_clk(void);<br /> void at24xx_ho_clk(void);<br /> void at24xx_write_byte(unsigned int);<br /> unsigned int at24xx_read_byte(void);<br /> public:<br /> void at24xx_write_datas(unsigned int,unsigned int,unsigned int *);<br /> void at24xx_read_datas(unsigned int,unsigned int,unsigned int *);<br />};<br /><br />//编译后提示<br />"at24c02.h", line 4: [F001] syntax error at or near symbol 'LZX_E2'<br /> |
