The light weight TCP/IP stack LW/IP 1.3.2 ported to eCos
 楼主| 清风一士 发表于 2010-2-2 15:17 | 显示全部楼层 |阅读模式
The light weight TCP/IP stack LW/IP 1.3.2 ported to eCos.Here is the NEWs on eCos mailing list.For more detail ,please refer to http://ecos.sourceware.org
lwIP 1.3.2 port
Simon Kallweit has contributed a port of lwIP 1.3.2 to eCos. lwIP is an implementation of the Internet Protocol Suite (TCP/IP) which is focused on reducing memory requirements for embedded systems. The eCos port is fully integrated with the eCos I/O layer, enabling use with both ethernet and serial interfaces.
Now I made a test of lwip ,this example can be found on tests directory of LWIP on eCos cvs code .The picture is my result on micro2440 platform
参加一下链接http://cw1501.blog.163.com/blog/static/9883327820100297409176/
winloop 发表于 2010-2-5 16:20 | 显示全部楼层
好东东
foxqiu 发表于 2010-2-22 20:55 | 显示全部楼层
what is ecos?is it a realtime operation system?open source?free get?many question i want to sak.
gaiwang42 发表于 2010-2-24 13:34 | 显示全部楼层
google
