[UNO] 基于Arduino UNO的LCD5110屏中文显示
5933|3
 楼主| jinglixixi 发表于 2016-12-25 11:43 | 显示全部楼层 |阅读模式
在常规的Arduino UNO驱动库中,对于LCD5110的驱动程序一般是缺少中文支持的,恰逢圣诞来临之际,就以“圣诞快乐”的界面制作来介绍一下实现中文显示的方法。
1. 3310液晶显示屏绘制提取程序来提取汉字字模,其操作如图1所示。
1 提取中文字模
2. 建立一个名为chinese.h的头文件,将字模存入该文件。
const unsigned char chinese_character[][24]=
        {0x40,0x42,0x26,0x2A,0x12,0xD2,0x12,0x2A,0x26,0x42,0x40,0x00,0x08,0x08,0x09,0x09,0x09,0x0F,0x09,0x09,0x09,0x08,0x08,0x00},
        {0x11,0xF2,0x00,0x72,0xCE,0x00,0xF2,0x02,0xFE,0x11,0x11,0x00,0x00,0x07,0x0A,0x04,0x0B,0x08,0x09,0x09,0x09,0x09,0x09,0x00},
        {0x78,0x00,0xFF,0x48,0x44,0x44,0xFF,0x44,0x44,0x7C,0x40,0x00,0x00,0x00,0x0F,0x08,0x04,0x03,0x00,0x03,0x04,0x08,0x08,0x00},
        {0x00,0x3E,0xA2,0x22,0x22,0xFA,0x21,0x21,0xA1,0x20,0x00,0x00,0x04,0x02,0x01,0x08,0x08,0x0F,0x00,0x00,0x00,0x01,0x06,0x00},
3. Arduino UNOLCD5110连接起来,其连接关系如下:
VCC      --  3.3V
GND     --  GND
LCD_CS   --  4
LCD_DIN  --  5
LCD_CLK  --  6
LCD_RST  --  7
LCD_DC   --  8
VO       -- 3.3V
4. LCD5110驱动库中添加语句 #include "chinese.h",以引入自行构建的小字库。然后再添加如下的汉字显示函数。
void LCD_write_hanzi(uint8_t X,uint8_t Y,uint8_t s)
    do
                char line;
                NOKIA5110_set_XY(X,Y);
                 for (line=0; line<12; line++)
                        NOKIA5110_write_byte(chinese_character[line], NOKIA5110_DATA);
                NOKIA5110_set_XY(X,Y+1);//LCD_set_XY(X,Y+1);
                for (line=12; line<24; line++)
          }while(0);
此外,再添加如下的主处理函数。
void Main_Deal ()
  NOKIA5110_init();
  NOKIA5110_clear_screen();
  LCD_write_hanzi(0,0,0);
  LCD_write_hanzi(12,0,1);
  LCD_write_hanzi(24,0,2);
  LCD_write_hanzi(36,0,4);
  NOKIA5110_display_8x6_text (0, 2, "merry christmas");
  NOKIA5110_display_8x6_text (0, 4, "  2016.12.24");
  while (1);
5. 经编译与下载,其显示效果如图2所示。
图2 中文显示效果
dirtwillfly 发表于 2017-1-24 16:05 | 显示全部楼层
 楼主| jinglixixi 发表于 2017-1-25 10:33 | 显示全部楼层
搁浅时光 发表于 2017-10-13 17:09 | 显示全部楼层
