5402&TLV2541 串口中断问题
 楼主| 天晓得 发表于 2010-4-23 20:30 | 显示全部楼层 |阅读模式
哪位大侠告诉我图片怎么粘贴啊?想粘个图片都不会,汗~
我的问题是我用5402的McBSP接收AD的数据,原来用查询可以,就是检测RRDY位。现在换用中断就只能进入一次中断,我很困惑……代码如下:
         .title  "TLV2541 C5402DSK McBSP0"
         .mmregs
   .def    _c_int00
   .def    BRINT0_ISR
         .width   80
         .length  55
    .sect ".vectors"
    .copy "C5402vec.asm"
    .sect ".data"
.include regs.h
**Local and Global variables defined**
AD_DP        .usect ".varibl", 0  ;Data page label for variables.
ADWORD       .usect ".varibl", 1  ;Temporarily Store Sample in this variable
Temp     .usect ".varibl", 1
    .sect ".text"
_c_int00:
***Initialize DSP***
DP=#0;        ;Memory Mapped Registers in Data Page 0
          ;Set DSP Clock Frequency
CLKMD =#0       ;Switch to DIV mode
TstStatu:
A=CLKMD        ;Test Clock Mode Status
A &= #01b       ;mask out PLL status bit
if (ANEQ ) goto TstStatu   ;wait until DIV mode is enabled
CLKMD = #4007h      ;Set c5402 DSP clock to 100MHz.
    SP=#3CFFh       ;Set Stack pointer
    INTM=#1        ;Disable all interrupts.
SXM=#0              ;No Sign Extension
CPL=0        ;DP used for relative addressing
PMST = #00a0h        ;Re-map Interrupt Vector Table to 0x0080h in Program Memory
  IMR  = #0010h         ;enable RINT0 interrupts
IFR  = #0FFFFh        ;Clear all Pending Interrupts
SWWSR = #2000h          ;Need Wait-State of at least 2.
DP=#ADWORD       ;Change Data Page to where Variables are stored.
    @Temp=#0001h      ;Set CPLD
port(DSP_CPLD_CNTL2) [email==@Temp]=@Temp[/email]    ;Select daughter board as source for McBSP0
    call McBSP0_init     ;Intialize McBSP0
INTM=#0        ;Enable global interrupts
    DP=#AD_DP       ;
AR7=#3200h          ;Address to store Samples at.
*Begin conversion cycle*
A=#0000h
mmr(McBSP0_DXR1)=A       ;Loading Accum. A with 0x0 to generate FSX/R pulse.
HERE:
repeat(#1000)      ;Do nothing.  Allow enough time for conversion
    NOP
goto HERE
BRINT0_ISR:
PUSH (ST0)
PUSH (ST1)
PUSH (AR2)      ;Save Registers
PUSH (AR1)
PUSH (AR0)
   DP=#AD_DP
AR2=#McBSP0_DRR1
NOP
    B=*AR2        ;Read out Reciever and store in Accumulator B
    B=B<<<-4       ;Shift data to right by 4
@ADWORD=B       ;Move 12-bit WORD to ADWORD
repeat(#280)      ;Do nothing.  Allow enough time for conversion
    NOP
AR0=#3400h          ;Table ends at 0x3400h
DP=#ADWORD          ;Load Data Page Pointer with data page of ADWORD
TC     = (AR0 == AR7)         ;is AR7 = AR0? (table end reached?)
   if (TC) goto Reset_Data_Table    ;If table end reached move reset pointer to begining
            ;of table
*AR7+  = data(@ADWORD)        ;Store 12-bit Sample at location pointed to by AR7
goto BACK
Reset_Data_Table:
AR7=#3200h       ;Point to first position in data table
BACK:
A=#0000h
  AR0 =POP()
    AR1 =POP()
    AR2 =POP()
ST1 =POP()
ST0 =POP()
  RETURN
**Function Configures McBSP0**
McBSP0_init:
mmr(McBSP0_SPSA) = #SPCR1      ;Reset McBSP0 Receiver
A=mmr(McBSP0_SPSD)
A = #0FFFEh & A       ;RRST*=0
mmr(McBSP0_SPSD) =A
repeat(#5)
    NOP
mmr(McBSP0_SPSA) = #SPCR2       ;Reset McBSP0 Receiver
A=mmr(McBSP0_SPSD)
A= A & #0FF7Fh     ;FRST*=0
A= A & #0FFBFh                  ;GRST*=0
A= A & #0FFFEh                  ;XRST*=0
A=A|#0200h      ;enable free running mode
mmr(McBSP0_SPSD) = A     ;
    repeat(#5)
    NOP
mmr(McBSP0_SPSA) = #PCR         ;FSXM & CLKXM output pin driven
mmr(McBSP0_SPSD) = #0A00h       ;by Sample Rate Generator
         ;FSRM & CLKRM input pins
         ;driven by external source
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #RCR1        ;
mmr(McBSP0_SPSD) = #0040h       ;One 16-bit Word per frame
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #RCR2        ;One 16-bit Word per frame
mmr(McBSP0_SPSD) = #0041h       ;one bit receive bit data delay
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #XCR1
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #XCR2        ;One 16-bit Word per frame
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #SRGR1       ;FSX/R is one clock width
A=#0009h
mmr(McBSP0_SPSD) = A         ;SRG clock divider=9 (CPU Clock /1+CLKGDV)=10Mhz
repeat(#6)
    NOP
mmr(McBSP0_SPSA) = #SRGR2       ;SRG lcok derived from CPU clock
mmr(McBSP0_SPSD) = #2000h       ;FSX due to transfer DXR->XSR
                                    ;32 sclks
repeat(#6)
    NOP
A=mmr(McBSP0_SPSD)
A= A | #0040h                   ;GRST*=1
    mmr(McBSP0_SPSD)  = A        ;Frame Generator and sample
            ;sample-rate generator enabled
    repeat(#6)
    NOP
A= A | #0001h                   ;XRST*=1
    mmr(McBSP0_SPSD)  = A        ;Transmitter enabled
    repeat(#6)
    NOP
    mmr(McBSP0_SPSA) = #SPCR1    ;RRST*=1
A= mmr(McBSP0_SPSD)
A= A | #0001h
mmr(McBSP0_SPSD) = A   ;Reciever enabled
repeat(#6)
    NOP
RETURN
.end
