*** Using Compiler 'V5.06 update 2 (build 183)', folder: 'F:\KEIL\ARM\ARMCC\Bin'
Rebuild target 'Target 1'
assembling Startup.s...
Startup.s: Error: A9555E: License checkout for feature LIC0=TA...-.....-..... with version 5.0201601 has been denied by Keil back-end. Error code: 1
Startup.s: error: Serial does not match product requested
Startup.s: Product: MDK Professional 5.20
Startup.s: Component: ARM Compiler 5.06 update 2 (build 183)
Startup.s: Tool: ArmAsm [4d35b2]
compiling main.c...
Error: C9555E: License checkout for feature LIC0=TA...-.....-..... with version 5.0201601 has been denied by Keil back-end. Error code: 1
Keil Licensing error: Serial does not match product requested
Tool: ArmCC [4d35cd]
".\Objects\123.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:00
