Building configuration: Point Clock - Debug
Updating build tree...
main.c
Linking
Error[e16]: Segment CODE (size: 0x207c align: 0x2) is too long for segment definition. At least 0x1d4 more bytes needed. The problem occurred while processing the
segment placement command "-Z(CODE)CODE=ROMSTART-ROMEND", where at the moment of placement the available memory ranges were
"CODE:40000158-40001fff"
Reserved ranges relevant to this placement:
40000000-4000003b INTVEC
4000003c-40000157 ICODE
40000158-40001fff CODE
Total number of errors: 1
Total number of warnings: 0 |
