明远智睿MY-IMX6-EK140 Linux-3.14 测试手册
1210|0
 楼主| 明远智睿2017 发表于 2018-3-20 16:15 | 显示全部楼层 |阅读模式
linux, mx, TE, ST, IO
测试前的准备(preparation before test)
1)请按照《Linux快速启动手册》中的“Linux快速启动” -> “连接设备”进行连接。
please follow the path of 《Linux fast boot manual》->“Linux fast boot” -> “connect device”for connection
2)请按照《Linux快速启动手册》中的“Linux快速启动” -> “启动设备”进行启动。
please follow the path of 《Linux fast boot manual》->“Linux fast boot” -> “boot device”for booting
测试项目(test item)
网口测试( test of network interface)
MY-IMX6-EK140支持一个百兆网口。
MY-IMX6-EK140 support one Mbps network interface
接口属性(interface property)
评估板型号
(evaluation board model)
CPU接口
(CPU interface)
系统接口
(system interface)
接口丝印
(interface silk screen)
MY-IMX6-EK140ENET1eth0P1
测试方法(test method)
1)        配置计算机IP
configure computer IP
设置计算机有线网卡IP为192.168.18.18
set IP of cable network interface card for computer as 192.168.18.18
2)        Eth0连接测试
Eth0 test for Wth0 connection
  • 连接网线:将评估板“eth0”对应的接口与计算机有线网卡的接口用网线相连接
lan line connection:connect interface corresponding to “eth0”on evaluation board with interface of cable network interface card on computer through lan line
  • 设置评估板IP:
set IP for evaluation board
# ifconfig eth0 192.168.18.36 # configure the eth0
  • 执行测试命令:
execute test command
# ping 192.168.18.18 -c 2 -w 4 # send ICMP to HOST
  • 观察测试结果:系统会输出类似如下信息:
view test result,you can see information outputed by system like below
--- 192.168.18.18 ping statistics ---
2packets transmitted, 2 packets received, 0% packet loss
  • 测试结果:“0% packet loss”表示测试通过
test reuslt:“0% packet loss” represent passing of test
  • 附图
figures
USB测试(USB test)接口属性(interface property)
评估板型号
CPU接口
(CPU interface)
系统接口
(system interface)
接口丝印
MY-IMX6-EK140USB_OTG1USB OTGJ4
USB_OTG2USB HOSTJ7[…]
USB OTG测试(USB OTG test)
1)        将MicroUSB转USB的转接线连接到USB1,系统会输出类似如下信息:
connect to USB1 with USB switch wiring from MicroUSB,system will output information like below.
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
2)        连接USB设备。即:将U盘插入转接线上的USB口,系统会输出类似如下信息:
connect USB device,e.g insert U disk to USD port on the switch wiring,system will output information like below.
usb 2-1: new high-speed USB device number 12 using ci_hdrc
usb-storage 2-1:1.0: USB Mass Storage device detected
3)        拔出USB设备,系统会输出类似如下信息:
take out USB device,system will output information like below.
usb 2-1: USB disconnect, device number 12
4)        拔下USB转接线,系统会输出类似如下信息:
take out USB switch wiring,system will output information like below.
ci_hdrc ci_hdrc.0: remove, state 4
usb usb2: USB disconnect, device number 1
ci_hdrc ci_hdrc.0: USB bus 2 deregistered
USB HOST测试(USB HOST test)
  MY-IMX6-EK140 的USB HOST是插座形式,如要测试HOST功能,需要把自备USB头,并且将插座上的USB HOST信号线连接到USB头,此操作请找自己的硬件工程师请求支持。
  MY-IMX6-EK140 USB HOST is socket type,if need to test the function of HOST,need to connect signal line of USB HOST to the USB head self-prepared, the operation need an assistance from hardware engineer.
  另外,请硬件工程师知晓,由于CPU的USB_VBUS供电能力不足,需要将“5V_core”与USB_VBUS相连。
  Moreover,please let engineer know that power supply capability of CPU的USB_VBUS is not enough,so need to connect“5V_core”with USB_VBUS
附图(figure)
SD卡测试(SD card test)接口属性(interface property)
评估板型号
CPU接口
(CPU interface)
系统设备
(system device)
接口丝印
MY-IMX6-EK140SD1mmc0U15
测试说明(test instruction)
MY-IMX6-EK140的TF卡接口不支持热插拔。
MY-IMX6-EK140的TF card interface doesn't support hot plug
测试方法(test method)
1)为MY-IMX6-EK140断电。
power off MY-IMX6-EK140
2)将TF卡安装好板子的TF卡座上,并确认安装好。
install TF card in TF card holder,and confirm the installation ok
3)为MY-IMX6-EK140上电,待系统启动完成后进入系统。
power on MY-IMX6-EK140,enter the system after booting is finished
5)检查TF卡:
check TF card
# dmesg | grep "mmc0"
TF卡正常则可以看到类似如下信息:
if IF card is normal, then you can see information like below.
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SD card at address 0002
附图(figure)
标准GPIO测试(standard GPIO test)接口属性(interface property)
评估板型号
CPU接口
(CPU interface)
系统设备
(system device)
信号名称
(name of signal)
接口位置
(interface position)
MY-IMX6-EK140SNVS_TAMPER3gpio131SNVS_TAMPER3J7:31
SNVS_TAMPER7gpio135SNVS_TAMPER7J7:32
标准GPIO的测试以GPIO131为例,其它GPIO测试可参照GPIO131的测试方法。
take GPIO131 as an example of standard GPIO test,other GPIO tests refer to the test method of GPIO131
测试方法(test method)
1)设置需要测试的GPIO的IO序号
set IO order number of GPIO which need to be tested
# OUT_IO_NUMBER=131
2)导出GPIO
lead out GPIO
# echo ${OUT_IO_NUMBER} > /sys/class/gpio/export
3)设置GPIO方向
set direction for GPIO
# echo "out" > /sys/class/gpio/gpio${OUT_IO_NUMBER}/direction
4)控制输出电平
control output electrical level
# echo 0 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
执行命令后即可用万用表检测到对应的引脚为低电平。
leads detected by multimeter accordingly will be low electrical level after execution of command
# echo 1 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
执行命令后即可用万用表检测到对应的引脚为高电平。
leads detected by multimeter accordingly will be high electrical level after execution of command
附图(figure)
GPIO-LED测试(GPIO-LED test)接口属性(interface property)
评估板型号
SOC接口
(SOC interface)
系统设备
(system device)
接口位置
MY-IMX6-EK140SNVS_TAMPER4defaultD1
SNVS_TAMPER1HeartbeatD2
SNVS_TAMPER8led-timerD4
SNVS_TAMPER5leds-gpioD5
GPIO-LED(Default)测试(GPIO-LED(Default)test)
Default的实现是初始触发状态为on,即系统启动后开发板上对应接口位置的LED常亮。
Default可以通过brightness控制。
往brightness写0即把该IO拉低,LED常灭。
# echo 0 > /sys/class/leds/default/brightness
往brightness写1即把该IO拉高,LED常亮。
# echo 1 > /sys/class/leds/default/brightness
GPIO-LED(Heartbeat)测试(GPIO-LED(Heartbeat) test)
系统启动完成后,可以在开发板上看到Heartbeat对应接口位置的LED在闪烁。
GPIO-LED(Timer)测试(GPIO-LED(Timer)test)
系统启动完成后,可以在开发板上看到led-timer对应接口位置的LED在闪烁:
通过delay_off、delay_on来控制高低电平持续的时间。
# echo 500 > /sys/class/leds/led-timer/delay_off
# echo 1000 > /sys/class/leds/led-timer/delay_on
再看led-timer对应的LED灯,在闪烁过程中可以发现亮的时间比灭的时间长。
GPIO-LED(leds-gpio)测试(GPIO-LED(leds-gpio)test)
GPIO的测试可以使用跟default类似的方法:
# echo 1 > /sys/class/leds/leds-gpio/brightness
# echo 0 > /sys/class/leds/leds-gpio/brightness
串口测试(serial port test)
MY-IMX6-EK140共8个串口,其中1个调试串口,7个用户串口。
串口属性(property of serial port)
评估板型号
SOC接口
(SOC interface)
系统设备
(system device)
信号名称
(name of signal)
接口位置
MY-IMX6-EK140UART1ttymxc0UART1_*J7
UART2ttymxc1UART2_*J1
UART3ttymxc2UART3_*J1
UART4ttymxc3UART4_*J1
UART5ttymxc4UART5_*J1
UART6ttymxc5UART6_*J1
UART7ttymxc6UART7_*J1
UART8ttymxc7UART8_*J1
串口测试(interface)
1)测试说明
测试的应用程序会配置串口为loopback模式,并进行loopback测试。测试中我们以UART2(ttymxc1)为例。
2)执行测试命令
# /unit_tests/mxc_uart_stress_test.out /dev/ttymxc1 115200 D L 10 1000 O
终端显示“Hit enter to start Loopback”后按下PC上的回车键。
测试命令说明:
/unit_tests/mxc_uart_stress_test.out:测试程序文件
/dev/ttymxc1:需要进行测试的串口设备文件
115200:串口测试的波特率
D:关闭流控(loopback测试不能使用流控)
L:loopback 测试
10:测试次数
1000:测试的数据长度(字节)
O:显示测试log
附图(figure)
SPI测试(SPI test)接口属性(interface property)
测试需要用到SPI接口的MISO和MOSI管脚,在下表中列出。
评估板型号
SOC接口
(SOC interface)
系统设备
(system device)
信号名称
(name of signal)
接口位置
MY-IMX6-EK140ECSPI1spidev0.0ECSPI1_*J7:[23,25,…]
ECSPI2spidev1.0ECSPI2_*J7:[24,26,…]
说明(instruction)
采用SPI自发送(输出)自接收(输入)的方式。
注意:测试需要短接评估板的管脚,如果不确定自己能正确短接的请找硬件工程师支持,否则可能会损坏评估板。
测试方法(test method)
1)执行测试
  • SPI1测试
短接SPI1的MISO和MISO管脚。
# ~/my-demo/linux-3.14.52/spidev_test.out -D /dev/spidev0.0 -s 1000000
  • SPI2测试
短接SPI2的MISO和MISO管脚。
# ~/my-demo/linux-3.14.52/spidev_test.out -D /dev/spidev1.0 -s 1000000
2)测试结果
如果SPI正常,在终端上会看到如下字符:
FF FF FF FF FF FF
40 00 00 00 00 95
FF FF FF FF FF FF
FF FF FF FF FF FF
FF FF FF FF FF FF
DE AD BE EF BA AD
F0 0D
附图(figure)
背光测试(test of backlight)接口属性(interface property)
评估板型号
SOC接口
(SOC interface)
系统设备
(system device)
信号名称
(name of signal)
接口位置
MY-IMX6-EK140PWM4backlight.8PWM4--
测试方法(test method)
1)查看背光可支持的最大亮度等级
# cat /sys/devices/soc0/backlight.8/backlight/backlight.8/max_brightness
2)查看当前背光亮度等级
# cat /sys/devices/soc0/backlight.8/backlight/backlight.8/brightness
3)控制背光亮度等级(下面命令将背光等级调到3)
# echo 3 > /sys/devices/soc0/backlight.8/backlight/backlight.8/brightness
可以看到显示屏的亮度发生了变化。
附图(figure)
CAN接口测试 (CAN interface test)接口属性(interface property)
评估板型号
SOC接口
(SOC interface)
系统设备
(system device)
信号名称
(name of signal)
接口位置
MY-IMX6-EK140CAN1can0CAN1_*J1
CAN2can1CAN2_*J1
  MY-IMX6-EK140从CPU上引出了CAN信号,但是在EK140上不带CAN收发芯片,所以不能直接测试CAN。如果需要测试CAN的收发,需要外接CAN收发芯片或CAN收发器。
RTC测试(RTC test)测试说明(test instruction)
1)受快递运输影响,开发板发货时不带电池。测试RTC前请自备纽扣电池并安装到评估板上。
2)MY-IMX6-MB140不带RTC,RTC在MY-IMX6-EXT140上,没有EXT140的客户可跳过此测试。
3)MY-IMX6-EK140的电池座在底板背面。
测试方法(test method)
1)断电重启设备,系统启动完成后查看当前系统时间和硬件时间。
# date
# hwclock
2)设置系统时钟,并同步到RTC芯片
# hwclock –w
3)断电重启评估板,查看当前系统时钟和硬件时钟
# date
# hwclock
附图(figure)
WatchDog测试(WatchDog test)测试说明(test instruction)
WatchDog测试包括2项:一项是复位测试,一项是喂狗测试。
复位测试(re-set test)
1)测试说明
复位测试将启动WatchDog,但是并不喂狗,超时后系统将会复位。
2)执行测试
# /unit_tests/wdt_driver_test.out 2 4 1
3)测试结果
运行测试命令后等待几秒,WatchDog超时,系统被复位。将会在终端看到系统重新启动输出的信息。
喂狗测试 (test of feeding dog)
1)测试说明
喂狗测试将启动WatchDog,并且每2秒钟进行1次喂狗,系统将不会因为WatchDog超时而复位。
2)执行测试
  • 启动WatchDog
# /unit_tests/wdt_driver_test.out 4 2 1 &
  • 查看当前时间
# date
3)验证
  • 查看当前时间
经过几分钟之后,系统依然没有复位。我们再查看当前时间。
# date
  • 停止喂狗
这时我们终止Watchdog测试程序,这样就没有程序进行喂狗了,系统将会在超时时间(这里是4秒)内复位。
# pkill wdt_driver_test
