[STM32] Keil编译出现如下错误,网上找不到解决办法,请求大佬帮助
 楼主| 晓枫、残月 发表于 2018-6-27 17:45 | 显示全部楼层 |阅读模式
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'H:\MDK5\ARM\ARMCC\Bin'
Build target '多彩流水灯'
assembling startup_stm32f429_439xx.s...
startup_stm32f429_439xx.s: Error: A9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
startup_stm32f429_439xx.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
startup_stm32f429_439xx.s:  http://www.keil.com/support/man/docs/license/license_management.htm
startup_stm32f429_439xx.s:  If you need further help, provide this complete error report to your supplier or license.support@arm.com.
startup_stm32f429_439xx.s:  - ARMLMD_LICENSE_FILE: unset
startup_stm32f429_439xx.s:  - LM_LICENSE_FILE: unset
startup_stm32f429_439xx.s:  - ARM_TOOL_VARIANT: unset
startup_stm32f429_439xx.s:  - ARM_PRODUCT_PATH: unset
startup_stm32f429_439xx.s:  - Product location: product not found
startup_stm32f429_439xx.s:  - Toolchain location: H:\MDK5\ARM\ARMCC\Bin
startup_stm32f429_439xx.s:  - Selected tool variant: mdk_cm_pro
startup_stm32f429_439xx.s: Product: unknown
startup_stm32f429_439xx.s: Component: ARM Compiler 5.06 update 5 (build 528)
startup_stm32f429_439xx.s: Tool: ArmAsm [4d35e1]
compiling system_stm32f4xx.c...
Error: C9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
Product: unknown
Tool: ArmCC [4d3621]
compiling misc.c...
xyz549040622 发表于 2018-6-27 19:53 来自手机 | 显示全部楼层
你**了吗?
ayb_ice 发表于 2018-6-28 09:02 | 显示全部楼层
一看就是没有**或没有**成功
梦幻泡影 发表于 2018-7-5 12:01 | 显示全部楼层
楼上说的没错,软件环境没搞好
千岁寒 发表于 2018-7-6 09:22 | 显示全部楼层
找个 keil 注册机,给keil注册一下。或者打个path。
qqlaoban 发表于 2023-6-20 23:41 | 显示全部楼层
我把keil重装了一下,先不**keil,直接装arm compiler 5,配置好编译器路径这些参数,再**keil就好了
