本人刚开始学习TMS320F28335开发板,使用音频模块的时候有如下两个问题,还请前辈们解答:
1、使用lab7例程时,为什么停止仿真之后为什么语音录放不暂停?
2、当我把中断函数里的代码屏蔽之后还可以正常录放音,难道录放音的实现与中断没有关系?
- #include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
- #include "DSP2833x_Examples.h" // DSP2833x Examples Include File
- Uint16 volume,tAicRegs;
- int ADbuf[500];
- int DA_wptr,DA_rptr,y;
- Uint16 play_mode=1;
- void main(void)
- Uint16 temp,i;
- // Step 1. Initialize System Control:
- // PLL, WatchDog, enable Peripheral Clocks
- // This example function is found in the DSP2833x_SysCtrl.c file.
- InitSysCtrl();
- // Step 2. Initalize GPIO:
- // This example function is found in the DSP2833x_Gpio.c file and
- // illustrates how to set the GPIO to it's default state.
- // InitGpio(); // Skipped for this example
- // For this example, only enable the GPIO for McBSP-A
- InitXintf16Gpio();
- InitMcbspaGpio();
- EALLOW;
- GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0; //aic_dat 0为数字IO模式,1为外设IO模式
- GpioCtrlRegs.GPADIR.bit.GPIO12 = 1; //0为输入方向,1为输出方向
- GpioCtrlRegs.GPAPUD.bit.GPIO12 = 0; //使能内部上拉电阻
- GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 0; //aic_CS
- GpioCtrlRegs.GPADIR.bit.GPIO13 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO13 = 0;
- GpioCtrlRegs.GPBMUX2.bit.GPIO61 = 0; //aic_clk
- GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;
- GpioCtrlRegs.GPBPUD.bit.GPIO61 = 0;
- EDIS;
- // Step 3. Clear all interrupts and initialize PIE vector table:
- // Disable CPU interrupts
- DINT;
- // Initialize PIE control registers to their default state.
- // The default state is all PIE interrupts disabled and flags
- // are cleared.
- // This function is found in the DSP2833x_PieCtrl.c file.
- InitPieCtrl(); //IER\IFR寄存器清零
- // Disable CPU interrupts and clear all CPU interrupt flags:
- IER = 0x0000;
- IFR = 0x0000;
- // Initialize the PIE vector table with pointers to the shell Interrupt
- // Service Routines (ISR).
- // This will populate the entire table, even if the interrupt
- // is not used in this example. This is useful for debug purposes.
- // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
- // This function is found in DSP2833x_PieVect.c.
- InitPieVectTable(); //**初始化向量表(为PIE向量表中的所有中断向量配置对应向量的入口地址)
- // Step 4. Initialize all the Device Peripherals:
- // This function is found in DSP2833x_InitPeripherals.c
- // InitPeripherals(); // Not required for this example
- InitMcbspa(); // Initalize the Mcbsp-A in loopback test mode
- // tAicRegs = 0xFF;
- // SysReg = tAicRegs;
- InitAic23(); //aic23配置(单步调试声音变大)
- delay(500);
- volume=90;
- WriteAic23(L_HEADPHONE_VOLUME,0x0180+volume);//改变音量
- EALLOW; // This is needed to write to EALLOW protected registers
- PieVectTable.MRINTA = &ISRMcbspSend; //把函数的地址赋值给中断向量MRINTA的向量地址中
- EDIS; // This is needed to disable write to EALLOW protected registers
- PieCtrlRegs.PIECTRL.bit.ENPIE = 1; // Enable the PIE block
- PieCtrlRegs.PIEIER6.bit.INTx5=1; // Enable PIE Group 6, INT 5
- IER |= M_INT6; // Enable CPU INT6
- EINT; // Enable Global interrupt INTM
- while(1)
- for(temp=30000;temp>0;temp-=100)
- for(i=0;i<2;i++)
- y=5000;
- delay(temp); //播放警报
- // McbspaRegs.DXR1.all = y;
- y=-5000;
- interrupt void ISRMcbspSend(void)
- // int temp;
- // PieCtrlRegs.PIEACK.all = PIEACK_GROUP6;
- // temp=McbspaRegs.DRR1.all;
- // DA_rptr++;
- // if(DA_rptr>=500)
- // DA_rptr=0;
- // ADbuf[DA_rptr]=temp; //保存录音数据
- // if(play_mode==0)
- // //警报声的幅值
- // else
- // McbspaRegs.DXR1.all = temp; //放音
