[其它] android5.1里面的user-app的默认权限设置!
855|0
 楼主| kuangzl123 发表于 2018-11-28 15:53 | 显示全部楼层 |阅读模式
在 frameworks/base/services/core/java/com/android/server/AppOpsPolicy.java中:
public boolean isControlAllowed(int code, String packageName) {
        boolean isShow = true;
        int show = CONTROL_UNKNOWN;
        PolicyPkg pkg;
        String key;
        String type;
        if (mPolicy == null) {
            return isShow;
        type = getAppType(packageName);
        if (type != null) {
            key = type;
            pkg = mPolicy.get(key);
            if (pkg != null && pkg.show != CONTROL_UNKNOWN) {
                show = pkg.show;
        key = packageName;
        if (type != null) {
            key = key + "." + type;
        if (pkg != null) {
            if (pkg.show != CONTROL_UNKNOWN) {
                show = pkg.show;
            PolicyOp op = pkg.get(code);
            if (op != null) {
                if (op.show != CONTROL_UNKNOWN) {
                    show = op.show;
        }else {
            if(code == AppOpsManager.OP_CAMERA)
                show = CONTROL_NOSHOW;
        if (show == CONTROL_NOSHOW) {
            isShow = false;
        return isShow;
public int getDefualtMode(int code, String packageName) {
        int mode = AppOpsManager.MODE_ERRORED;
        PolicyPkg pkg;
        String key;
        String type;
            return mode;
        if (DEBUG)
            Slog.d(TAG, "Default mode requested for op=" + code + " package="
                    + packageName);
        if (type != null) {
            // Get value based on 'type'
            key = type;
            if (pkg != null && pkg.mode != AppOpsManager.MODE_ERRORED) {
                if (DEBUG)
                    Slog.d(TAG, "Setting value based on type: " + pkg);
                mode = pkg.mode;
        // Get value based on 'pkg'.
        key = packageName;
        if (type != null) {
        if (pkg != null) {
            if (pkg.mode != AppOpsManager.MODE_ERRORED) {
                if (DEBUG)
                    Slog.d(TAG, "Setting value based on packageName: " + pkg);
                mode = pkg.mode;
            // Get value base on 'op'
            if (op != null) {
                if (op.mode != AppOpsManager.MODE_ERRORED) {
                    if (DEBUG)
                        Slog.d(TAG, "Setting value based on op: " + op);
                    mode = op.mode;
        }else {
                mode = AppOpsManager.MODE_ALLOWED;
        if (DEBUG)
        Slog.d(TAG, "Returning mode=" + mode);
        return mode;
可以设置所有的用户APP默认打开摄像头的权限。
如果是要设置为允许某个用户APP默认打开摄像头权限,请打开/device/qcom/common/appops/appops_policy.xml,
<appops-policy version="1">
    <user-app permission="ask" show="true"/>
    <system-app permission="allowed" show="false"/>
    <application>
    <!-- Example:
        <pkg name="com.android.dialer" type="system-app">
            <op name="android:call_phone" permission="ask" show="true"/>
        </pkg>
        <pkg name="com.android.calendar" type="system-app">
            <op name="android:read_contacts" permission="ask" show="true"/>
        </pkg>
        <pkg name="com.android.email" type="system-app">
        </pkg>
         <pkg name="com.huayusoft.barcodeadmin" type="user-app">
            <op name="android:camera" permission="allow" show="false"/>
        </pkg>
   </application>
</appops-policy>
以上是两种设置默认权限的方式!
AP7350开发板6735平台是android 5.1 可以测试下
