[上位机系统管理] c#上位机串口快速接收发
1190|0
 楼主| haylang 发表于 2019-2-12 10:15 | 显示全部楼层 |阅读模式
         private void Form1_Load(object sender, EventArgs e)
            serialPort1.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived);//必须手动添加事件处理程序
            SearchAndAddSerialToComboBox(serialPort1, comboBox1);
            count = 0; idcount = 0; timecnt = 0;
private void port_DataReceived(object sender, SerialDataReceivedEventArgs e)//串口数据接收事件
            string dataRe;
            byte[] byteRead = new byte[serialPort1.BytesToRead];// 重新定义
            DeleUpdateTextbox deleupdatetextbox = new DeleUpdateTextbox(UpdateTextbox);
            serialPort1.Read(byteRead, 0, byteRead.Length);//获取串口接收到的字
              for (int i = 0; i < byteRead.Length; i++)
                byte temp = byteRead;
                dataRe = temp.ToString("X2");// +" ";//字符串格式控制符 X为十六进制 2为每次都是两位数
                textBox1.Invoke(deleupdatetextbox, dataRe);
