谁有sdio的最新标准
 楼主| guojian6 发表于 2011-11-3 15:36 | 显示全部楼层 |阅读模式
从理论上这种总线的速度可以到多少呀,能否支持到802.11n呀
 楼主| guojian6 发表于 2011-11-3 15:52 | 显示全部楼层
果然有3.0呀
zhqs425 发表于 2011-11-3 15:56 | 显示全部楼层
是可以的!!!
 楼主| guojian6 发表于 2011-11-3 16:42 | 显示全部楼层
• Bus Speed Mode (using 4 parallel data lines) (1) Default Speed mode: 3.3V signaling, Frequency up to 25 MHz, up to 12.5 MB/sec (2) High Speed mode: 3.3V signaling, Frequency up to 50 MHz, up to 25 MB/sec (3) SDR12: 1.8V signaling, Frequency up to 25 MHz, up to 12.5MB/sec (4) SDR25: 1.8V signaling, Frequency up to 50 MHz, up to 25MB/sec (5) SDR50: 1.8V signaling, Frequency up to 100 MHz, up to 50MB/sec (6) SDR104: 1.8V signaling, Frequency up to 208 MHz, up to 104MB/sec (7) DDR50: 1.8V signaling, Frequency up to 50 MHz, sampled on both clock edges, up to 50MB/sec • Switch function command supports Bus Speed Mode, Command System, Drive Strength,
 楼主| guojian6 发表于 2011-11-3 16:45 | 显示全部楼层
搜资料还是用谷歌强点,百度半天都没有得到,goolge下就出来了!
    标准支持就好,可以到104MB/sec 比usb2.0还强呀,那位推荐个好用sdio的wifi 802.11n ?谢谢!
汽车电子 发表于 2011-11-3 16:54 | 显示全部楼层
因为封锁,Google经常访问不了
