[C语言] 求解!!!!!!!??????
 楼主| 大树25144456 发表于 2019-7-8 17:42 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<stdio.h>
#define uchar unsigned char;
uchar code dispbit[]= {0x00,0x01,0x02,0x03};
uchar code dispcode[]= {0x3f,0x06,0x5b,0x4f,0x66,0x7d,0x07,0x7f,0x6f,0x00,};
uchar dispbuf[4]= {0,0,0,0};
uchar T0count;
uchar timecount;
bit flag;
unsigned long f,Rt,RL,Rs;
float Ct,V;
uchar i,j,k,l,m;
sbit S1=P3^6;
sbit S2=P3^7;
sbit PD=P3^2;
sbit ST=P2^6;
#define V2_ON {ST=0};
#define V02_ON{ST=0};
void t0(void)interrupt 1 using 1
    T0count++;
void t1 (void)interrupt 3 using 1
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
timecount++;
if(timecount==4)
   TR0=0;
        timecount=0;
        flag=1;
void delay()
  for(m=0;m<=2;m++);
         for(j=0;j<=100;j++);
void disp()
  for(i=0;i<4;i++)
     dispbuf[i]=0;
                        i=0;
                while(V/10)
      dispbuf[i]=(int)V%10;
                        V=V/10;
                        i++;
                 dispbuf[i]=V;
                 timecount=0;
                 T0count=0;
                 TH0=0;
                 TL0=1;
                 TR0=1;
                 for(k=0;k<4;k++);
void initial()
TR1=1;
TR0=1;
ET0=l;
ET1=1;
EA=1;
void main()
        TMOD=0X15;
        TH0=0;
        TL0=0;
        ST=1;
  timecount=0;
        Ct=4.7;Rt=10;
        RL=360;Rs=36;
while(1)
                V2:V2_ON;
    ST=1;
                delay_ms(1000);
      1=4;
                        initial();
                        datahandle();
                        disp();
      else
        goto V02;
    V02:V02_ON;
        1=3;
        ST=0;
        initial();
        datahandle();
        disp();
c(83): error C141: syntax error near '}'
这是什么情况啊,求解答  呜呜
