谁能提供一个读USB的类?
741|9
 楼主| pengf 发表于 2019-11-15 22:24 | 显示全部楼层 |阅读模式
这几天老做一些底层的东西,API又不熟,谁能提供一个读USB的类?
 楼主| pengf 发表于 2019-11-15 22:26 | 显示全部楼层
明天买本API的书看看吧。。不想学都不行。。
morrisk 发表于 2019-11-15 22:30 | 显示全部楼层
你哪本书是C#操作USB口的吗?
zyf部长 发表于 2019-11-15 22:33 | 显示全部楼层
用C#操作比较麻烦吧?
 楼主| pengf 发表于 2019-11-15 22:38 | 显示全部楼层
没有现成的读USB口的例子吗?
xxmmi 发表于 2019-11-15 22:40 | 显示全部楼层
自己找个现成的库文件,调用就行了。
zwll 发表于 2019-11-15 22:47 | 显示全部楼层
USB这东西哟,感觉底层简单,上层协议复杂程度可以和TCPIP相比了
kangzj 发表于 2019-11-15 22:51 | 显示全部楼层
最好找个实例看看,CY的芯片都会有相应的API手册。
 楼主| pengf 发表于 2019-11-15 22:54 | 显示全部楼层
唉,还是没有什么结果,算了,先结贴吧,多谢大家啦
probedog 发表于 2024-1-17 16:28 | 显示全部楼层
cpp
#include <windows.h>
#include <winusb.h>
class USBReader
private:
    HANDLE deviceHandle;
    WINUSB_INTERFACE_HANDLE winusbHandle;
    ULONG bufferSize;
    PUCHAR buffer;
    ULONG transferSize;
public:
    USBReader(const char* devicePath)
        // Open a handle to the USB device.
        deviceHandle = CreateFile(devicePath, GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
        if (deviceHandle == INVALID_HANDLE_VALUE) {
            printf("Error: Unable to open USB device handle.\n");
            return;
        // Claim the interface to get a WinUSB handle.
        DWORD interfaceNumber = 0; // The interface number to open.
        DWORD alternateSetting = 0; // The alternate setting of the interface to open.
        DWORD deviceHandleSize = sizeof(deviceHandle);
        if (!WinUsb_ClaimInterface(deviceHandle, &interfaceNumber, &winusbHandle)) {
            printf("Error: Unable to claim USB interface.\n");
            CloseHandle(deviceHandle);
            return;
        // Allocate a buffer for receiving data from the USB device.
        bufferSize = 64 * 1024; // The size of the buffer to allocate. Adjust this based on your needs.
        buffer = (PUCHAR)malloc(bufferSize);
        if (!buffer) {
            printf("Error: Unable to allocate memory for the USB buffer.\n");
            WinUsb_Free(winusbHandle);
            return;
    ~USBReader()
        free(buffer);
    bool ReadData()
        // Set up the transfer parameters. Adjust these based on your needs.
        ULONG transferLength = 0; // The length of the data to transfer. Adjust this based on your needs.
        ULONG transferOffset = 0; // The offset at which to start reading data from the device. Adjust this based on your needs.
        if (!WinUsb_ReadPacket(winusbHandle, transferOffset, buffer, transferLength, &transferSize, 0)) { // Read the data from the device. Adjust this based on your needs.
            printf("Error: Unable to read data from the USB device.\n");
            return false;
        } else {
            // Do something with the data that was read from the USB device. This might involve printing it or storing it in a file. Adjust this based on your needs.
            printf("Read %d bytes of data from the USB device.\n", transferSize); // Print the number of bytes that were read. Adjust this based on your needs.
            return true; // Return true if the data was read successfully, false otherwise. Adjust this based on your needs.
