/* 酒店客房管理系统 */ import java.util.Scanner;//通过键盘来输入命令需要的引入 class HotelManangerSystem { public static void main(String[] args) { //酒店有12个楼层,每层有10个房间 //字符串数组如果没有被初始化,每个元素都是null String[][] rooms = new String[12][10]; System.out.println("欢迎来到蒋氏集团大酒店");//换行打印 System.out.println("请输入要操作的命令:search查询,in办理入住,out退房" + "init初始化所有房间"); Scanner s = new Scanner(System.in);//这个在主函数定义的,其他函数用不了 while(true) { String command = s.next();//提示输入命令 //比较字符串相同--"输入的字符串".equals(command) if("init".equals(command)) { init(rooms); System.out.println("房间初始化完毕"); } else if("search".equals(command)) { search(rooms); } else if("in".equals(command)) { in(rooms); } else if("out".equals(command)) { out(rooms); } } } //初始化所有的房间号 public static void init(String[][] rooms) { for(int i = 0; i < 12; i++) { for(int j = 0; j < 10;j++) { rooms[i][j] = "EMPLY"; } } } public static void search(String[][] rooms) { for(int i = 0; i < rooms.length; i++) { for(int j = 0; j < rooms[i].length;j++) { if(i < 9) { System.out.print("0"); } int roomNum = (i + 1) * 100 + j + 1; System.out.print(roomNum + "\t"); } System.out.println(); for(int k = 0; k < rooms[i].length; k++) { System.out.print(rooms[i][k] + "\t"); } System.out.println(); } } public static void in(String[][] rooms) { System.out.println("请输入房间号:"); Scanner s = new Scanner(System.in); int roomNum = s.nextInt(); int i = roomNum / 100; int j = roomNum % 100; if(i < 1 || i > 10 || j < 1|| j > 12) { System.out.println("输入错误,请重新输入in:"); return; } if(rooms[i-1][j-1] != "EMPLY") { System.out.println("此房间已经有人入住,请重新输入in:"); return; } System.out.println("请输入您的姓名:"); String name = s.next(); rooms[i-1][j-1] = name; System.out.println("入住成功"); } public static void out(String[][] rooms) { System.out.println("请输入房间号:"); Scanner s = new Scanner(System.in); int roomNum = s.nextInt(); int i = roomNum / 100; int j = roomNum % 100; if(i < 1 || i > 10 || j < 1|| j > 12) { System.out.println("输入错误,请重新输入out:"); return; } if(rooms[i-1][j-1] == "EMPLY") { System.out.println("输入错误,请重新输入out:"); return; } if(rooms[i-1][j-1] != "EMPLY") { rooms[i-1][j-1] = "EMPLY"; System.out.println("退房成功"); } } }最近初次接触JAVA,感觉之前学的C语言很有用,跟着视频做了一个小项目-酒店客房管理系统
举报
本版积分规则 发表回复 回帖后跳转到最后一页
323
1820
19
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
