f_write() 与 f_read() 写入数量和读取数量不一致
552|0
 楼主| 没名字的人 发表于 2020-4-24 17:28 | 显示全部楼层 |阅读模式
f_write()返回数据 数量是 15
f_read()返回数据 数量是 19
但是 写入数据和读取数据时正确的
这是怎么回事啊!
UINT fs1num,fs2num;                                                        /* 文件成功读写数量 */
BYTE fs1ReadBuffer[1024]={0};                        /* 读缓冲区 */
BYTE fs2ReadBuffer[1024]={0};                        /* 读缓冲区 */
BYTE fs1WriteBuffer[] = "fs1 自定义数据";                                /* 写缓冲区*/
BYTE fs2WriteBuffer[] = {"fs2 自定义数据"};                                /* 写缓冲区*/
        printf("\n****** New file three.txt ******\r\n");
        strcpy(f_name,"three.txt");
        res_fs1 = f_open(&fs1, "1:three.txt", FA_READ|FA_WRITE|FA_OPEN_ALWAYS);
        if(res_fs1 == FR_OK)
                {        printf(" %s 文件打开 Success ! \n",f_name);
                        res_fs1 = f_write(&fs1, fs1WriteBuffer, sizeof(fs1WriteBuffer), &fs1num);
                                {        printf(" %s 文件写入 Success ! \n",f_name);
                                        printf("sizeof(fs1WriteBuffer) = %d 写入数据 %d 个 \n",sizeof(fs1WriteBuffer),fs1num); // fs1num = 15
                                        printf(" 数据为-->%s \n", fs1WriteBuffer);
                        else
                                {        printf(" %s 文件写入 Fail ! \n",f_name);
                f_close(&fs1);
                printf(" %s 文件关闭 ! \n",f_name);
        else
                {        printf(" %s 文件打开 Fail !\n",f_name);
                        res_fs1 = f_read(&fs1, fs1ReadBuffer, sizeof(fs1ReadBuffer), &fs1num);
                                {        printf(" %s 文件读取 Success ! \n",f_name);
                                        printf(" 读取数据 %d 个 \n",fs1num); // fs1num = 19
                                        printf(" 数据为-->%s \n", fs1ReadBuffer);
                        else
                f_close(&fs1);
                else
