[综合信息] 华大HC32F003☆ ---WDT例程分享(部分一)
 楼主| LED2013 发表于 2020-8-7 10:15 | 显示全部楼层 |阅读模式
☆适用领域:小家电,充电器,重合闸,遥控器,电子烟,燃气报警器,数显表,温控器,记录仪等行业。
☆ 华大MCU单片机资料分享连接
HC32F003 HC32F005 HC32L110 HC32L136 HC32F030 HC32M140 HC32F146 HC32L150 HC32L156
/ \file main.c
** A detailed description is available at
** @link Sample Group Some description @endlink
** - 2017-05-17 1.0 CJ First version for Device Driver Library of Module.
  • Include files
#include “wdt.h”
#include “lpm.h”
#include “gpio.h”
  • Local pre-processor symbols/macros (’#define’)
  • Global variable definitions (declared in header file with ‘extern’)
  • Local type definitions (‘typedef’)
  • Local function prototypes (‘static’)
  • Local variable definitions (‘static’) *
    #define T1_PORT (0)
    #define T1_PIN (3)
  • Function implementation - global (‘extern’) and local (‘static’)
** \brief Main function of project
** \return uint32_t return value, if needed
** This sample
uint8_t u32CountWdt;
uint8_t Data=0xff;
uint8_t cnt=0;
static void WdtCallback(void)
// comment following to demonstrate the hardware watchdog reset
Data = ~Data;
Gpio_SetIO(T1_PORT,T1_PIN,Data);
u32CountWdt++;
int32_t main(void)
stc_wdt_config_t stcWdt_Config;
stc_lpm_config_t stcLpmCfg;
DDL_ZERO_STRUCT(stcWdt_Config);DDL_ZERO_STRUCT(stcLpmCfg);stcLpmCfg.enSLEEPDEEP = SlpDpDisable;//SlpDpEnable;stcLpmCfg.enSLEEPONEXIT = SlpExtEnable;Gpio_InitIO(T1_PORT,T1_PIN,GpioDirOut);Gpio_SetIO(T1_PORT,T1_PIN,0);Gpio_InitIO(3,3,GpioDirIn);stcWdt_Config.u8LoadValue = 0x0b;//3.2sstcWdt_Config.enResetEnable = WINT_EN;//WRESET_EN;////stcWdt_Config.pfnWdtIrqCb = WdtCallback;Clk_SetPeripheralGate(ClkPeripheralWdt,TRUE);//Wdt_Init(&stcWdt_Config);Wdt_Start();Gpio_SetIO(T1_PORT,T1_PIN,1);
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
  • 11
  • 12
  • 13
  • 14
  • 15
  • 16
  • 17
  • 18
  • 19
#if 0
while(1 == Gpio_GetIO(3,3));//注意:此处如果用户测试深度休眠模式,此处不能屏蔽
Lpm_Config(&stcLpmCfg);
Lpm_GotoLpmMode();
#endif
while (1)
//cnt = Wdt_ReadWdtValue();
//Wdt_Feed();//测试喂狗功能时,放开屏蔽
作者:虹芯侠客1
来源:CSDN
原文:https://blog.csdn.net/jetson024/article/details/84619088
版权声明:本文为博主原创**,转载请附上博文链接!
观海 发表于 2020-9-4 13:16 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-9-4 13:17 | 显示全部楼层
额 排版不行啊
heimaojingzhang 发表于 2020-9-4 13:18 | 显示全部楼层
看的我头疼
keaibukelian 发表于 2020-9-4 13:21 | 显示全部楼层
没看太明白
labasi 发表于 2020-9-4 13:22 | 显示全部楼层
支持楼主一下吧
快速回复 返回顶部 返回列表
