华为的鸿蒙OS的开源版权声明属于哪类?
 楼主| steelen 发表于 2020-9-11 11:51 | 显示全部楼层 |阅读模式
这是代码中的版权声明
这个版权声明属于哪类?
* Copyright (c) 2013-2019, Huawei Technologies Co., Ltd. All rights reserved.
* Copyright (c) 2020, Huawei Device Co., Ltd. All rights reserved.
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice, this list of
*    conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice, this list
*    of conditions and the following disclaimer in the documentation and/or other materials
*    provided with the distribution.
* 3. Neither the name of the copyright holder nor the names of its contributors may be used
*    to endorse or promote products derived from this software without specific prior written
*    permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
潜力变实力 发表于 2020-9-11 15:34 | 显示全部楼层
版权声明就是指权利人对自己创作或获得许可作品权利的一种口头或书面主张,一般包括权利归属、作品使用许可方式、责任追究等方面的内容.如平时看电影时前面会有一个“警告”的片断,其实就是版权声明;版权声明用得比较普遍的领域是网站,一般在网站的页脚就有“版权声明”.
 楼主| steelen 发表于 2020-9-16 16:01 | 显示全部楼层
我的意思是这属于哪声明?
GPL,LGPL?EPL?LEPL?
阿帕奇声明?
BSD声明
还是MIT声明
