Edgexfoundry加载设备服务的过程
6286|6
 楼主| keer_zu 发表于 2020-10-31 23:18 | 显示全部楼层 |阅读模式
在加载device-modbus-go后,日志里看到注册失败后容器就退出了,尝试分析一下原因
先看日志:
  1. root@ubuntu:/home/zkq/Downloads/edinburgh# docker-compose logs -f device-modbus
  2. Attaching to edgex-device-modbus
  3. edgex-device-modbus | level=INFO ts=2020-10-31T08:24:42.848270036Z app=edgex-device-modbus source=config.go:219 msg="Loaded configuration from /res/configuration.toml"
  4. edgex-device-modbus | level=INFO ts=2020-10-31T08:24:42.848645165Z app=edgex-device-modbus source=config.go:167 msg="Using Configuration provider (consul) from: http://edgex-core-consul:8500 with base path of edgex/devices/1.0/edgex-device-modbus"
  5. edgex-device-modbus | level=INFO ts=2020-10-31T08:24:42.882899665Z app=edgex-device-modbus source=config.go:330 msg="Configuration has been pushed to into Configuration Provider (0 environment overrides applied)"
  6. edgex-device-modbus | level=ERROR ts=2020-10-31T08:24:42.882948498Z app=edgex-device-modbus source=logger.go:74 msg="logTarget cannot be blank, using stdout only"
  7. edgex-device-modbus | level=INFO ts=2020-10-31T08:24:42.883091308Z app=edgex-device-modbus source=registry.go:79 msg="Using Registry (consul) from http://localhost:8500"
  8. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:42.912259473Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  9. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:43.942224395Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  10. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:44.983199131Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  11. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:46.023003154Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  12. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:47.051487665Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  13. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:48.102145115Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  14. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:49.142052336Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  15. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:51.320764465Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  16. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:52.362954685Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  17. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:53.392423592Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  18. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:54.422118509Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  19. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:55.447075414Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  20. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:56.472188582Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  21. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:57.502974713Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  22. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:58.52875264Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  23. edgex-device-modbus | level=WARN ts=2020-10-31T08:24:59.557093942Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  24. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:00.60329459Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  25. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:01.640430577Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  26. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:02.68214448Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  27. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:03.722795915Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  28. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:04.76403472Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  29. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:05.803131314Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  30. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:06.836045349Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  31. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:07.861176081Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  32. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:08.902148952Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  33. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:09.962716024Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  34. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:11.006160592Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  35. edgex-device-modbus | level=WARN ts=2020-10-31T08:25:12.044084896Z app=edgex-device-modbus source=registry.go:139 msg="registry is not available"
  36. edgex-device-modbus | level=ERROR ts=2020-10-31T08:25:13.045021233Z app=edgex-device-modbus source=bootstrap.go:43 msg="unable to register with Registry in allotted time"
  37. edgex-device-modbus exited with code 1
顺藤摸瓜,看看服务注册的过程:
从入口开始
@21ic小管家 给个编辑推荐吧 原创  发表于 2020-10-31 23:20
 楼主| keer_zu 发表于 2020-10-31 23:26 | 显示全部楼层
 楼主| keer_zu 发表于 2020-11-1 01:50 | 显示全部楼层
  3. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.347691415Z app=edgex-device-modbus source=config.go:219 msg="Loaded configuration from /res/docker/configuration.toml"
  4. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.399158697Z app=edgex-device-modbus source=config.go:112 msg="Config Provider URL created from Registry configuration"
  5. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.414804097Z app=edgex-device-modbus source=config.go:167 msg="Using Configuration provider (consul) from: http://edgex-core-consul:8500 with base path of edgex/devices/1.0/edgex-device-modbus"
  6. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.913274902Z app=edgex-device-modbus source=config.go:330 msg="Configuration has been pushed to into Configuration Provider (0 environment overrides applied)"
  7. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.914172183Z app=edgex-device-modbus source=registry.go:79 msg="Using Registry (consul) from http://edgex-core-consul:8500"
  8. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:54.997753413Z app=edgex-device-modbus source=httpserver.go:99 msg="Web server starting (0.0.0.0:49991)"
  9. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.000940152Z app=edgex-device-modbus source=init.go:134 msg="Check Metadata service's status via Registry..."
  10. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.002213917Z app=edgex-device-modbus source=init.go:134 msg="Check Data service's status via Registry..."
  11. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.047448576Z app=edgex-device-modbus source=init.go:42 msg="Service clients initialize successful."
  12. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.061234935Z app=edgex-device-modbus source=service.go:83 msg="Device Service edgex-device-modbus doesn't exist, creating a new one"
  13. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.068012488Z app=edgex-device-modbus source=service.go:140 msg="Addressable edgex-device-modbus doesn't exist, creating a new one"
  14. edgex-device-modbus | level=ERROR ts=2020-10-31T17:28:55.198251001Z app=edgex-device-modbus source=profiles.go:180 msg="Error when retrieving EnableValueDescriptorManagement configuration from Core Metadata: map[LogLevel:INFO]"
  15. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.425458513Z app=edgex-device-modbus source=message.go:50 msg="Service dependencies resolved..."
  16. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.425823592Z app=edgex-device-modbus source=autodiscovery.go:19 msg="AutoDiscovery stopped: disabled by configuration"
  17. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.428511364Z app=edgex-device-modbus source=message.go:51 msg="Starting edgex-device-modbus 1.0.0 "
  18. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.449331321Z app=edgex-device-modbus source=message.go:55 msg="device modbus started"
  19. edgex-device-modbus | level=INFO ts=2020-10-31T17:28:55.459066101Z app=edgex-device-modbus source=message.go:58 msg="Service started in: 1.125770971s"
 楼主| keer_zu 发表于 2020-11-1 01:51 | 显示全部楼层
kosten 发表于 2021-6-2 17:21 | 显示全部楼层
你解决modbus报错registry is not available 这个方法,没太明白,能详细了解下吗?  我是直接使用docker-compose拉的容器,启动的时候直接报这个错误
 楼主| keer_zu 发表于 2021-6-2 17:58 | 显示全部楼层
你解决modbus报错registry is not available 这个方法,没太明白,能详细了解下吗?  我是直接使用docker-c ...
检查一下配置看看,时间久了,忘记了
1488
