edgex:连接一个应用
424|0
 楼主| keer_zu 发表于 2020-12-8 11:40 | 显示全部楼层 |阅读模式
edge, ic, AN, ui, ST
1.4. Connecting an ApplicationEdgeX provides exporters for a variety of cloud services and application. To keep this guide simple, we’re going to use a public MQTT broker hosted by HiveMQ, then watch for our EdgeX readings to be pushed to it automatically.
To register the application as an export client, run:
  1. <span class="n">curl</span> <span class="o">-</span><span class="n">X</span> <span class="n">POST</span> <span class="o">-</span><span class="n">d</span> <span class="s1">'{</span>
  2.     <span class="s2">"name"</span><span class="p">:</span><span class="s2">"QuickStartExport"</span><span class="p">,</span>
  3.     <span class="s2">"addressable"</span><span class="p">:{</span>
  4.         <span class="s2">"name"</span><span class="p">:</span><span class="s2">"HiveMQBroker"</span><span class="p">,</span>
  5.         <span class="s2">"protocol"</span><span class="p">:</span><span class="s2">"tcp"</span><span class="p">,</span>
  6.         <span class="s2">"address"</span><span class="p">:</span><span class="s2">"broker.hivemq.com"</span><span class="p">,</span>
  7.         <span class="s2">"port"</span><span class="p">:</span><span class="mi">1883</span><span class="p">,</span>
  8.         <span class="s2">"publisher"</span><span class="p">:</span><span class="s2">"EdgeXExportPublisher"</span><span class="p">,</span>
  9.         <span class="s2">"topic"</span><span class="p">:</span><span class="s2">"EdgeXQuickStartGuide"</span>
  10.     <span class="p">},</span>
  11.     <span class="s2">"format"</span><span class="p">:</span><span class="s2">"JSON"</span><span class="p">,</span>
  12.     <span class="s2">"filter"</span><span class="p">:{</span>
  13.         <span class="s2">"deviceIdentifiers"</span><span class="p">:[</span><span class="s2">"Random-Integer-Generator01"</span><span class="p">]</span>
  14.     <span class="p">},</span>
  15.     <span class="s2">"enable"</span><span class="p">:</span><span class="n">true</span><span class="p">,</span>
  16.     <span class="s2">"destination"</span><span class="p">:</span><span class="s2">"MQTT_TOPIC"</span>
  17. <span class="p">}</span><span class="s1">' http://localhost:48071/api/v1/registration</span>
You can connect to this broker with any MQTT client to watch the data being sent. HiveMQ provides a web-based client that you can use, simply subscribe to the “EdgeXQuickStartGuide” topic and you will begin seeing your random number readings.
EdgeX_HiveMQTTWebClient.png You can also use the Mosquitto CLI tool to verify that readings are being sent by running:
  1. <span class="n">mosquitto_sub</span> <span class="o">-</span><span class="n">h</span> <span class="n">broker</span><span class="o">.</span><span class="n">hivemq</span><span class="o">.</span><span class="n">com</span> <span class="o">-</span><span class="n">p</span> <span class="mi">1883</span> <span class="o">-</span><span class="n">t</span> <span class="n">EdgeXQuickStartGuide</span>
1488
