Features
3.0V to 60V Wide Input Voltage
Integrated 250mΩ 60V Power MOSFET
Up to 95% Step-up conversion efficiency
Low than 0.1mA static current
1.2MHz Fixed Switching Frequency
1mA Light load model efficiency up to 80%
Low than 10uA Shutdown current
Built-in Cycle-by-cycle current limiting
Built-in thermal shutdown protection
Built-in under-voltage protection
Built-in loop compensatio
Built-in soft start circuit
Simple external circuit
Available in a 6-pin SOT-23 package
General Description
The is a constant frequency,
mode step-up converter intended
for small, low power applications. The
switches at 1.2MHz and allows
the use of tiny, low cost capacitors and
inductors 5mm or less in height. Internal
soft-start results in small inrush current
and extends battery life.
The includes under-voltage
lockout, current limiting, and thermal
overload protection to prevent damage in
the event of an output overload. The
is available in a small 6-pin
SOT-23 package.
ZCC6303恒流驱动_datasheet_V1.0.pdf
(829.79 KB, 下载次数: 1)
