int Input_caputre3(void)
        T3CON        = 0x8030;
        IC3CON = 0;
        IC3CONbits.ICTMR = 0;        //Select Timer3 as the IC3 Time base
        IC3CONbits.ICSIDL = 0;
        IC3CONbits.ICI = 0b0;                //每个捕捉事件中断一次
        IC3CONbits.ICM = 0b1;                //Capture mode, every edge (rising and falling)
        IPC9bits.IC3IP = 3; // Setup IC3 interrupt priority level
        IFS2bits.IC3IF = 0; // Clear IC3 Interrupt Status Flag
        IEC2bits.IC3IE = 1; // Enable IC3 interrupt
        return 1;
int Input_caputre1(void)
        T3CON        = 0x8030;                // 1:256 internal clock, start T3.
        IPC0bits.IC1IP  =  1;                         // Setup Input Capture 1 interrupt for desired priority
        // level (this example assigns level 1 priority)
        IFS0bits.IC1IF                 = 0;                 // Clear the IC1 interrupt status flag
        IEC0bits.IC1IE                 = 1;                 // Enable IC1 interrupts
        IC1CON                         = 0x0000;        // Turn off Input Capture 1 Module
        IC1CONbits.ICSIDL        = 0;                // Input capture module will continue to operate in CPU Idle mode
        IC1CONbits.ICTMR        = 0;                // TMR3 contents are captured on capture event
        IC1CONbits.ICI                = 0;                // Interrupt on every capture event
        IC1CONbits.ICM                = 1;                // Capture mode, every edge (rising and falling)
void __attribute__((__interrupt__,no_auto_psv))_IC1Interrupt(void)
        unsigned int t1;
        IFS0bits.IC1IF =  0;
        t1=IC1BUF;
        LATF=(PORTF ^ 0xff);
        //IC1flag = 1;
void __attribute__((__interrupt__,no_auto_psv))_IC3Interrupt(void)
        unsigned int t1;
        IFS2bits.IC3IF = 0;
        t1=IC3BUF;
