[全新] 5V多节锂电(2~4节)同步升压管理芯片ZCC6983
281|0
 楼主| SWdianzi 发表于 2021-12-31 16:32 | 显示全部楼层 |阅读模式
特性
3.0V to 5.5V Operating Input Voltage
Up to 26V Sustainable Voltage
Up to 2A Configurable Charge Current for Battery
with 2~4 Cells in Series
Configurable Input Voltage Limit
Charge Status Indication
Constant Voltage Selectable
Programmable Charge Timeout
Thermal Regulation Protection
External Shutdown Function
Input Voltage UVLO and OVP
Over Temperature Protection
Output Short Cir cuit Protec tion Normal
Synchronous Boost Operation When Battery
Removed
描述
ZCC6983 is a highly integrated synchronous boost
charger IC for Lithium-ion batteries with four cells in
series . The charge current up to 2A can be
programmed by using the external resistor for different
portable applications.
Robust protections include input over-voltage
protection (OVP), battery OVP, battery short protection,
thermal shut down, battery temperature monitor, a
configurable timer to prevent prolonged charging of a
dead battery.
