PSoC Designer 5.4 SPI 编译出错
610|3
 楼主| P胖子 发表于 2022-1-7 09:01 | 显示全部楼层 |阅读模式
Starting MAKE...
psocmakemake.exe test2 -oproject.mk
creating project.mk
name translation failed on D:/zhongling_software/PSoC\ designer\ 5.4/PSoC\ Designer/5.4/Common/CypressSemiBuildMgr - 3
name translation failed on D:\zhongling_software\PSoC - 2
name translation failed on designer - 2
name translation failed on 5.4\PSoC - 3
name translation failed on Designer\5.4\Common\CypressSemiBuildMgr\tools\include\CY8C29000 - 3
mkdepend.exe -f project.dep -p./obj/ -o.o -- -I/tools/include -I./lib -I./std -I.   -- main.c  boot.asm
mkdepend.exe @mkdep
mkdepend.exe @mkdep
if exist output\test2.rom del /F /Q  output\test2.rom
if exist output\test2.hex del /F /Q  output\test2.hex
iasm8c.exe -I/tools/include -I./lib -I./std -I.    -g -o lib/obj/lcd.o lib/lcd.asm
!E lib/lcd.asm(35): file 'm8c.inc' not found in current directory or in include path(s)
!E LCD.inc(25): file 'm8c.inc' not found in current directory or in include path(s)
!E lib/lcd.asm(206): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(214): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(259): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(272): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(304): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(309): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(343): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(344): no such mnemonic 'RAM_SETPAGE_IDX'
!E lib/lcd.asm(353): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(385): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(401): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(431): no such mnemonic 'RAM_PROLOGUE'
!E lib/lcd.asm(447): no such mnemonic 'RAM_EPILOGUE'
!E lib/lcd.asm(476): no such mnemonic 'RAM_PROLOGUE'
Too many errors, exiting...
make: *** [lib/obj/lcd.o] Error -1
make: *** Deleting file `lib/obj/lcd.o'
test2 - 18 error(s) 0 warning(s) 12:10:58
这个是什么情况?请帮忙看下是哪里设置出错了呢?
cr315 发表于 2023-12-26 16:20 | 显示全部楼层
检查引脚连接
两只袜子 发表于 2023-12-26 16:20 | 显示全部楼层
尝试更新 PSoC Designer 到最新版本,或卸载后重新安装。
jcky001 发表于 2023-12-26 16:20 | 显示全部楼层
检查库和依赖关系
