MPLAB IDE+Pkit3编译时报错,求助
1118|1
 楼主| ljh404 发表于 2022-1-26 09:58 | 显示全部楼层 |阅读模式
Executing: "F:\Microchip\MPLAB\MPASM Suite\mplink.exe" /p12F635 "main.o" /u_DEBUG /u_DEBUGCODESTART=0x300 /u_DEBUGCODELEN=0x100 /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /z__MPLAB_DEBUGGER_PK3=1 /z__ICD2RAM=1 /o"main.cof" /M"main.map" /W /x
MPLINK 4.49, Linker
Device Database Version 1.14
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000000, length=0x000006e8
Errors    : 1
Link step failed.
Debug build of project `G:\workspace_MPLAB\PIC12F635\TEST3\TEST3.mcp' failed.
Language tool versions: MPASMWIN.exe v5.51, mplink.exe v4.49, mplib.exe v4.49
Preprocessor symbol `__DEBUG' is defined.
Target debug platform is `__MPLAB_DEBUGGER_PK3=1'.
Debug platform options are: `__ICD2RAM=1'.
Wed Jan 26 09:53:16 2022
BUILD FAILED
lcczg 发表于 2022-1-28 09:31 | 显示全部楼层
是不是代码空间不够了?https://bbs.21ic.com/icview-796560-1-1.html
PS: 现在都用MPLAB X了。
