龙讯LT9711双端口MIPI/LVDS到DP1.2转换器总带宽高达16Gbps
 楼主| JLKJ18338421851 发表于 2022-3-24 13:50 | 显示全部楼层 |阅读模式
1. 描述
Lontium LT9711是双端口MIPI/LVDSDP1.2转换器,内部c型交替模式开关和PD控制器。
MIPI DSI/CSI输入具有可配置的单端口或双端口,1个时钟通道,1~4个数据通道,最大工作速率为2Gbps/lane,可支持总带宽高达16GbpsLT9711支持突发模式和非突发模式的DSI视频数据传输。
DP1.2输出由4个数据通道组成,支持RBR (1.62Gbps)HBR (2.7Gbps)HBR2 (5.4Gbps)链路速度。 内置的可选SSC功能减少电磁干扰影响有关的系统应用。
为了适应USB Type-C生态系统,LT9711集成了一个高性能双向超高速开关,由CC逻辑和PD管理单元控制,以减轻移动系统设计的复杂性和BOM成本。 switch功能兼容VESA DP交替模式USB Type-C标准。
LT9711是在先进的CMOS工艺制造和实现在一个小轮廓9x 9mm QFN76封装。 该封装符合RoHS标准,可在-40°C+85°C范围内工作。
2.  特性
MIPI / LVDS接收器
DP1.2发射机
•全功能USB Type-C
USB Type-C充电接口
•杂项
3. 应用程序
•移动系统、VR/AR
•手机、PAD/平板电脑
•数码摄像机
•数码静止相机
1. Description
The Lontium LT9711 is Dual-Port MIPI/LVDS to DP1.2 converter with internal Type-C Alternate Mode switch and PD controller.
The MIPI DSI/CSI input features configurable single-port or dual-port with 1 clock lane, and 1~4 data lanes operating at maximum 2Gbps/lane, which can support a total bandwidth up to 16Gbps. LT9711 supports both burst mode and non-burst mode DSI video data transferring.
For DP1.2 output, it consists of 4 data lanes, supporting RBR (1.62Gbps), HBR (2.7Gbps) and HBR2 (5.4Gbps) link speeds. The build-in optional SSC function reduces EMI effect on EMI-concerned system application.
In order to be adaptable to the USB Type-C ecosystem, LT9711 integrates a high performance bi-directional Super-Speed switch controlled by CC logic and PD management unit to relieve mobile system design complexity and BOM cost. The switch function is compliant with VESA DP Alternate Mode on USB Type-C Standard.
The LT9711 is fabricated in advanced CMOS process and implemented in a small outline 9x 9mm QFN76 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• MIPI/LVDS Receiver
• DP1.2 Transmitter
• Full-Featured USB Type-C
• USB Type-C Charging Port
• Miscellaneous
3. Applications
• Mobile systems, VR/AR
• Cellular handsets, PAD/Tablets
• Digital video cameras
• Digital still cameras
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
快速回复 返回顶部 返回列表
