龙迅LT86102UXE-HDMI2.0分割器
 楼主| JLKJ18338421851 发表于 2022-3-24 14:32 | 显示全部楼层 |阅读模式
1.描述
LontiumLT86102UXEHDMI2.0分割器具有1:2的分割器与HDMI2/1.4规范兼容,最大6Gbps高速数据速率,自适应均衡RX输入和预强调TX输出支持长电缆应用,内部TX车道交换灵活的PCB路由。
LT86102UXEHDMI2.0分光器自动检测线缆损耗,并自适应优化均衡设置。CDR消除了输入数据的抖动,使其适用于长电缆和级联应用。它支持RX终端电阻校准,以进一步提高信号完整性。
LT86102UXE支持DDC/SCDC兼容HDMI2.0/1.4规范。这个包是QFN769mmx9嗯呢它的运行温度为-40°C到+85°C。
2.特点
HDMI2.0接收器
HDMI2.0发射机
数字音频输出
杂项
3.应用
多显示器/电视支持
·HDMI/DVI信号分裂/重复
1. Description
The Lontium LT86102UXE HDMI2.0 Splitter features a 1:2 splitter compliant with HDMI2.0/1.4 specification, max 6Gbps high speed data rate, adaptive equalization RX input and pre-emphasized TX output to support long cable application, internal TX lane swap for flexible PCB routing.
LT86102UXE HDMI2.0 Splitter automatically detect the cable loss, and adaptively optimize the equalization setting .The CDR cleans the input  data jitter,  make it suitable for long cable and cascade application. It support RX termination resistor calibration to further improve signal integrity.
LT86102UXE support DDC/SCDC compliant with HDMI2.0/ 1.4 specification. This package is QFN76 9mmx9mm. It operates from −40°C to +85°C.
2. Features
• HDMI2.0 Receiver
• HDMI2.0 Transmitter
• Digital Audio Output
• Miscellaneous
3. Application
• Multiple display/TV support
• HDMI/DVI signal splitting/repeating
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!Email:bcxu.jl@foxmail.com
快速回复 返回顶部 返回列表
