- #include "sys.h"
- #include "stdio.h"
- /**************** define print uart ******************/
- #define PRINT_UART USART1
- #define PRINT_UART_CRM_CLK CRM_USART1_PERIPH_CLOCK
- #define PRINT_UART_TX_PIN GPIO_PINS_9
- #define PRINT_UART_TX_GPIO GPIOA
- #define PRINT_UART_TX_GPIO_CRM_CLK CRM_GPIOA_PERIPH_CLOCK
- #define PRINT_UART_TX_PIN_SOURCE GPIO_PINS_SOURCE9
- #define PRINT_UART_TX_PIN_MUX_NUM GPIO_MUX_1
- #define PRINT_UART_RX_PIN GPIO_PINS_10
- #define PRINT_UART_RX_GPIO GPIOA
- #define PRINT_UART_RX_GPIO_CRM_CLK CRM_GPIOA_PERIPH_CLOCK
- #define PRINT_UART_RX_PIN_SOURCE GPIO_PINS_SOURCE10
- #define PRINT_UART_RX_PIN_MUX_NUM GPIO_MUX_1
- #define PRINT_UART_IRQn USART1_IRQn
- #define PRINT_UART_IRQHandler USART1_IRQHandler
- #define PRINT_UART_REC_LEN 200 //定义最大接收字节数 200
- #define EN_RRINT_UART_RX 1 //使能(1)/禁止(0)串口1接收
- extern u8 PRINT_UART_RX_BUF[PRINT_UART_REC_LEN]; //接收缓冲,最大USART_REC_LEN个字节.末字节为换行符
- extern u16 PRINT_UART_RX_STA; //接收状态标记
- /* printf uart init function */
- void uart_print_init(uint32_t baudrate);
- #endif
usart.c
- #include "usart.h"
- u8 PRINT_UART_RX_BUF[PRINT_UART_REC_LEN]; //接收缓冲,最大USART_REC_LEN个字节.末字节为换行符
- //接收状态
- //bit15, 接收完成标志
- //bit14, 接收到0x0d
- //bit13~0, 接收到的有效字节数目
- u16 PRINT_UART_RX_STA=0;
- /* support printf function, usemicrolib is unnecessary */
- #if (__ARMCC_VERSION > 6000000)
- __asm (".global __use_no_semihosting\n\t");
- void _sys_exit(int x)
- x = x;
- /* __use_no_semihosting was requested, but _ttywrch was */
- void _ttywrch(int ch)
- ch = ch;
- FILE __stdout;
- #else
- #ifdef __CC_ARM
- #pragma import(__use_no_semihosting)
- struct __FILE
- int handle;
- FILE __stdout;
- x = x;
- ch = ch;
- #endif
- #endif
- #if defined (__GNUC__) && !defined (__clang__)
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif
- * [url=home.php?mod=space&uid=247401]@brief[/url] retargets the c library printf function to the usart.
- * @param none
- * @retval none
- PUTCHAR_PROTOTYPE
- while(usart_flag_get(PRINT_UART, USART_TDBE_FLAG) == RESET);
- usart_data_transmit(PRINT_UART, ch);
- return ch;
- * @brief initialize uart
- * @param baudrate: uart baudrate
- * @retval none
- gpio_init_type gpio_init_struct;
- /* enable the uart and gpio clock */
- crm_periph_clock_enable(PRINT_UART_CRM_CLK, TRUE);
- crm_periph_clock_enable(PRINT_UART_TX_GPIO_CRM_CLK, TRUE);
- crm_periph_clock_enable(PRINT_UART_RX_GPIO_CRM_CLK, TRUE);
- gpio_default_para_init(&gpio_init_struct);
- /* configure the uart tx pin */
- gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
- gpio_init_struct.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
- gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
- gpio_init_struct.gpio_pins = PRINT_UART_TX_PIN;
- gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
- gpio_init(PRINT_UART_TX_GPIO, &gpio_init_struct);
- gpio_pin_mux_config(PRINT_UART_TX_GPIO, PRINT_UART_TX_PIN_SOURCE, PRINT_UART_TX_PIN_MUX_NUM);
- /* configure the uart rx pin */
- gpio_init_struct.gpio_pins = PRINT_UART_RX_PIN;
- gpio_init(PRINT_UART_RX_GPIO, &gpio_init_struct);
- gpio_pin_mux_config(PRINT_UART_RX_GPIO, PRINT_UART_RX_PIN_SOURCE, PRINT_UART_RX_PIN_MUX_NUM);
- /* configure uart param */
- usart_init(PRINT_UART, baudrate, USART_DATA_8BITS, USART_STOP_1_BIT);
- usart_parity_selection_config(PRINT_UART, USART_PARITY_NONE);
- usart_transmitter_enable(PRINT_UART, TRUE);
- usart_receiver_enable(PRINT_UART, TRUE);
- usart_enable(PRINT_UART, TRUE);
- #if EN_RRINT_UART_RX
- /* config usart2 and usart1 nvic interrupt */
- nvic_irq_enable(PRINT_UART_IRQn, 0, 0);
- usart_interrupt_enable(PRINT_UART, USART_RDBF_INT, TRUE);//enable receiver interrupt
- // usart_interrupt_enable(PRINT_UART, USART_TDBE_INT, TRUE);//enable transmitter interrupt
- #endif
- void PRINT_UART_IRQHandler(void)
- u8 Res;
- if(usart_flag_get(USART1, USART_RDBF_FLAG) != RESET)
- /* read one byte from the receive data register */
- Res= usart_data_receive(PRINT_UART);
- if((PRINT_UART_RX_STA&0x8000)==0)//接收未完成
- if(PRINT_UART_RX_STA&0x4000)//接收到了0x0d
- if(Res!=0x0a)PRINT_UART_RX_STA=0;//接收错误,重新开始
- else PRINT_UART_RX_STA|=0x8000; //接收完成了
- else //还没收到0X0D
- if(Res==0x0d)PRINT_UART_RX_STA|=0x4000;
- else
- PRINT_UART_RX_BUF[PRINT_UART_RX_STA&0X3FFF]=Res ;
- PRINT_UART_RX_STA++;
- if(PRINT_UART_RX_STA>(PRINT_UART_REC_LEN-1))PRINT_UART_RX_STA=0;//接收数据错误,重新开始接收
- // if(usart_flag_get(USART1, USART_TDBE_FLAG) != RESET)
配置不同串口,尽仅需修改头文件即可~
main函数里面调用:
- system_clock_config();
- nvic_priority_group_config(NVIC_PRIORITY_GROUP_4);
- delay_init();
- uart_print_init(115200);
- LED_Init();
- while(1)
- if(PRINT_UART_RX_STA&0x8000)
- len=PRINT_UART_RX_STA&0x3fff;//得到此次接收到的数据长度
- printf("\r\n您发送的消息为:\r\n");
- for(t=0;t<len;t++)
- while(usart_flag_get(PRINT_UART, USART_TDBE_FLAG) == RESET);//等待发送结束
- usart_data_transmit(PRINT_UART, PRINT_UART_RX_BUF[t]);//向串口1发送数据
- printf("\r\n\r\n");//插入换行
- PRINT_UART_RX_STA=0;
- }else
- times++;
- if(times%5000==0)
- printf("\r\nAT-STRAT-F425 串口实验\r\n");
- printf("qjp1988113@21ic\r\n\r\n\r\n");
- if(times%200==0)printf("请输入数据,以回车键结束\r\n");
- if(times%30==0){led0_sta=1-led0_sta;LED0(led0_sta);}//闪烁LED,提示系统正在运行.
- delay_ms(10);
调试输出:
其中对于BITBAND 功能的外设的映射失败,无反应,查看半天也未看出问题。
我这里主要对GPIO的输入输出配置。
RM里面的描述:
- #define PER_BASE 0x40000000
- #define PER_BITBAND_BASE 0x42000000
- #define BITBAND(addr, bitnum) (PER_BITBAND_BASE + ((addr - PER_BASE) * 32) + ((bitnum) * 4))
- #define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
- #define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
- //IO口地址映射
- #define GPIOA_ODR_Addr (GPIOA_BASE+20) //0x40020014
- #define GPIOB_ODR_Addr (GPIOB_BASE+20) //0x40020414
- #define GPIOC_ODR_Addr (GPIOC_BASE+20) //0x40020814
- #define GPIOD_ODR_Addr (GPIOD_BASE+20) //0x40020C14
- #define GPIOE_ODR_Addr (GPIOE_BASE+20) //0x40021014
- #define GPIOF_ODR_Addr (GPIOF_BASE+20) //0x40021414
- #define GPIOA_IDR_Addr (GPIOA_BASE+16) //0x40020010
- #define GPIOB_IDR_Addr (GPIOB_BASE+16) //0x40020410
- #define GPIOC_IDR_Addr (GPIOC_BASE+16) //0x40020810
- #define GPIOD_IDR_Addr (GPIOD_BASE+16) //0x40020C10
- #define GPIOE_IDR_Addr (GPIOE_BASE+16) //0x40021010
- #define GPIOF_IDR_Addr (GPIOF_BASE+16) //0x40021410
- //IO口操作,只对单一的IO口!
- //确保n的值小于16!
- #define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n) //输出
- #define PAin(n) BIT_ADDR(GPIOA_IDR_Addr,n) //输入
- #define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n) //输出
- #define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n) //输入
- #define PCout(n) BIT_ADDR(GPIOC_ODR_Addr,n) //输出
- #define PCin(n) BIT_ADDR(GPIOC_IDR_Addr,n) //输入
- #define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n) //输出
- #define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n) //输入
- #define PEout(n) BIT_ADDR(GPIOE_ODR_Addr,n) //输出
- #define PEin(n) BIT_ADDR(GPIOE_IDR_Addr,n) //输入
- #define PFout(n) BIT_ADDR(GPIOF_ODR_Addr,n) //输出
- #define PFin(n) BIT_ADDR(GPIOF_IDR_Addr,n) //输入
实际定义LED0=PCout(2),并调用LED0=1;LED=0;无反应~
哪位大侠不吝赐教~
