- <span class="code-snippet__selector-tag" style="outline: 0px; max-width: 1000%; color: rgb(202, 125, 55); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"="">app</span><span class="code-snippet__selector-class" style="outline: 0px; max-width: 1000%; color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"="">.json</span><span style="color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);"=""> //小程序的公共配置文件,必须要有的</span>
- <span class="code-snippet__selector-tag" style="outline: 0px; max-width: 1000%; color: rgb(202, 125, 55); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"="">app</span><span class="code-snippet__selector-class" style="outline: 0px; max-width: 1000%; color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"="">.wxss</span><span style="color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);"=""> //小程序的公共样式表文件,非必须要有的</span>
小程序可以有多个页面文件,包含在多个页面文件夹中,上面的图片只是一个Pages页面的文件夹,还可以多建立几个页面文件夹。每个页面文件夹都包含四个文件。
- <code style="outline: 0px; max-width: 1000%; display: flex; position: relative;" liberation="" mono",="" menlo,="" courier,="" monospace;="" box-sizing:="" border-box="" !important;"=""><span class="code-snippet_outer" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;"><span class="code-snippet__selector-tag" style="outline: 0px; max-width: 1000%; color: rgb(202, 125, 55); box-sizing: border-box !important;">xxx</span><span class="code-snippet__selector-class" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">.wxml</span> //页面结构文件,必须的</span></code><code style="outline: 0px; max-width: 1000%; display: flex; position: relative;" liberation="" mono",="" menlo,="" courier,="" monospace;="" box-sizing:="" border-box="" !important;"=""><span class="code-snippet_outer" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;"><span class="code-snippet__selector-tag" style="outline: 0px; max-width: 1000%; color: rgb(202, 125, 55); box-sizing: border-box !important;">xxx</span><span class="code-snippet__selector-class" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">.json</span> //页面配置文件,非必须的</span></code><code style="outline: 0px; max-width: 1000%; display: flex; position: relative;" liberation="" mono",="" menlo,="" courier,="" monospace;="" box-sizing:="" border-box="" !important;"=""><span class="code-snippet_outer" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;"><span class="code-snippet__selector-tag" style="outline: 0px; max-width: 1000%; color: rgb(202, 125, 55); box-sizing: border-box !important;">xxx</span><span class="code-snippet__selector-class" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">.wxss</span> //页面样式表文件,非必须的</span></code>
下面我们新建一个页面文件,操作步骤如下:
将文件夹起名“123”
按照上图进行设置,会得到如下的文件夹。
我们想要编译哪个文件夹,就在如下位置进行选择。
点击添加编译模式,将启动界面设置为:
这样在编译的时候,就直接编译刚刚建立的123页面文件了。
注意:老刘遇到建立好文件夹之后,找不到新建文件夹的情况,重新下载了微信开发者工具之后,解决这个问题了。可能由于软件本身的问题。
二、界面显示文字的三种形式
我们可以在123.wxml文件中直接添加如下指令:
- <!--pages/123/123.wxml-->
- <span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""><<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span><span style="color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);"="">第一种方式,直接书写形式。</span><span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""></<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span>
2. 通过变量传递的方式进行显示:
我们在123.js文件中,data中增加一个变量i,对于小白的我们而言,注意写法。不然编译不通过,寻找bug会很麻烦。
添加绿色框中的一行之后,在123.wxml文件中进行变量传递。
- <span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""><<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span><span style="color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);"="">{{i}}</span><span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""></<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span>
注意,这里的双大括号,老刘在编译的时候,总是不过,最终发现是写法的问题。还有变量定义的时候,“ :”、引号的使用,需要习惯。
3.通过this.setData的方式传递
在data中对变量a进行初始化为空:
在onLoad函数中增加如下指令:
最后在123.wxml中进行展示
- <span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""><<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span><span style="color: rgb(51, 51, 51); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);"="">{{a}}</span><span class="code-snippet__tag" style="outline: 0px; max-width: 1000%; color: rgb(14, 156, 229); font-family: Consolas, " liberation="" mono",="" menlo,="" courier,="" monospace;="" font-size:="" 14px;="" letter-spacing:="" 0.544px;="" white-space:="" pre;="" background-color:="" rgba(0,="" 0,="" 0.03);="" box-sizing:="" border-box="" !important;"=""></<span class="code-snippet__name" style="outline: 0px; max-width: 1000%; box-sizing: border-box !important;">text</span>></span>
三、延伸onLoad及其它几个函数使用场景
a、小程序注册完成后,加载页面,触发onLoad方法。
b、页面载入后触发onShow方法,显示页面。
c、首次显示页面,会触发onReady方法,渲染页面元素和样式,一个页面只会调用一次。
d、当小程序后台运行或跳转到其他页面时,触发onHide方法。
e、当小程序由后台进入到前台运行或重新进入页面时,触发onShow方法。
f、当使用重定向方法wx.redirectTo(OBJECT)或关闭当前页返回上一页wx.navigateBack(),触发onUnload。
四、手机上将三种方式预览一下
结:
一天一点小知识,慢慢积累,生活充满节奏感。
