[无线通信] Routerboard DR6018-S V02 IPQ6010/IPQ6018/IPQ6000 802.11ax wifi6
 楼主| wallysJane 发表于 2022-4-26 16:17 | 显示全部楼层 |阅读模式
ip, TE, ar
Routerboard DR6018-S V02 IPQ6010/IPQ6018/IPQ6000 802.11ax wifi6 wireless
[color=rgba(0, 0, 0, 0.9)]QCN9074/QCN9024/QCN9072/IPQ6010/IPQ6018/IPQ6000/IPQ4029/IPQ4019/IPQ5018/IPQ8074A/IPQ8072A/QCA9880/QCA9882
Wireless:On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain,On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain, 4 x MMCX Connectors, wifi6
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
WEB: https://www.wallystech.com/
Wallys Communications(SuZhou)Co.,Ltd
https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
快速回复 返回顶部 返回列表
