[全新] ZCC9059替代RT9059
389|0
 楼主| SWdianzi 发表于 2022-5-11 15:30 | 显示全部楼层 |阅读模式
General Description
The Z CC9059 is a high performance positive voltage regulator
designed for use in applications requiring very low input
voltage and very low dropout voltage at up to 3A. It operates
with a VIN as low as 1V and VDD voltage 3V with
programmable output voltage as low as 0.8V. The Z CC9059
features ultra low dropout, ideal for applications where
VOUT is very close to VIN. Additionally, it has an enable
pin to further reduce power dissipation while shutdown.
The Z CC9059 provides excellent regulation over variations
in line, load and temperature. The Z CC9059 provides a power
good signal to indicate if the voltage level of VO reaches
90% of its rating value.
Features
Output Current up to 3A
High Accuracy ADJ Voltage 1.5%
Dropout Voltage 350mV @ 3A Typically
VOUT Power Good Signal
VOUT Pull Low Resistance when Disable
Current Limiting Protection
Thermal Shutdown Protection
RoHS Compliant and Halogen Free
Applications
 Notebook PC Applications
 Motherboard Applications
