[全新] 7-100V降压恒流输出无极调光LED驱动芯片ZCC3820
409|0
 楼主| SWdianzi 发表于 2022-6-10 17:57 | 显示全部楼层 |阅读模式
Description
The ZCC3820KC is a high-efficiency
step-down LED driver controller with a wide
input voltage range of 7V to 100V.
The ZCC7820KC employs a constant
off-time mode architecture that accurately
regulates LED current with a feedback
coming from an external current-sense
resistor. This control scheme optimizes circuit
stabilization and fast response time without
loop compensation. Its low 280mV average
feedback voltage reduces power loss and
improves the converter’s efficiency.
The ZCC7820KC implements PWM and
analog dimming together through the DIM
pin.
The ZCC7820KC also Includes thermal
overload protection in case of output
overload.
Features
 Wide 7V to 100V Input Range
 Able to Drive <2A LED Load
 Constant Off-time Control
 High Efficiency (90%)
 Analog and PWM Dimming
 Open LED Protection
 Short LED Protection
 Thermal Shutdown
 RoHS and Halogen free compliance.
 Available in SOP8 Package
Applications
 Low Voltage Halogen Replacement
 DC/DC or AC/DC LED DriverApplication
 Automotive/Decorative LED Lighting
 Emergency Lighting
 LED Backlighting
