- * bsp_iic.c
- * Created on: 2022-6-28
- * Author: pc
- #include "bsp_iic.h"
- #include "Usart.h"
- #include "stdio.h"
- I2C_SFRmap* I2C_Choose;
- void I2C_GPIO_init(void)
- GPIO_InitTypeDef I2C_GPIO_Init;
- PCLK_CTL0_Peripheral_Clock_Enable(PCLK_CTL0_GPIOBCLKEN,TRUE);
- I2C_GPIO_Init.m_Mode = GPIO_MODE_RMP;
- I2C_GPIO_Init.m_OpenDrain = GPIO_POD_OD;
- I2C_GPIO_Init.m_Pin = GPIO_PIN_MASK_4|GPIO_PIN_MASK_5;
- I2C_GPIO_Init.m_PullUp = GPIO_PULLUP;
- I2C_GPIO_Init.m_PullDown = GPIO_NOPULL;
- I2C_GPIO_Init.m_Speed = GPIO_HIGH_SPEED;
- GPIO_Configuration(GPIOB_SFR,&I2C_GPIO_Init);
- // GPIOB_SFR->RMP[0] = 0x880000;
- GPIO_Pin_RMP_Config(GPIOB_SFR,GPIO_Pin_Num_4,GPIO_RMP_AF8_I2C0);
- GPIO_Pin_RMP_Config(GPIOB_SFR,GPIO_Pin_Num_5,GPIO_RMP_AF8_I2C0);
- #define IIC_100K
- void I2C_init_Master(I2C_SFRmap* I2Cx)
- I2C_Reset(I2Cx);
- I2C_InitTypeDef newStruct_I2C;
- newStruct_I2C.m_Mode = I2C_MODE_I2C;
- newStruct_I2C.m_ClockSource = I2C_CLK_HFCLK;
- newStruct_I2C.m_BADR10 = I2C_BUFRADDRESS_7BIT;
- newStruct_I2C.m_MasterSlave = I2C_MODE_SMBUSHOST; //
- #ifdef IIC_100K
- newStruct_I2C.m_BaudRateL = 80;
- newStruct_I2C.m_BaudRateH = 80;
- #elif defined IIC_400K
- newStruct_I2C.m_BaudRateL = 115; //I2C锟斤拷锟斤拷锟绞低碉拷平时锟斤拷锟斤拷锟斤拷 锟斤拷锟街�锟斤拷锟斤拷小锟斤拷3
- newStruct_I2C.m_BaudRateH = 115; //I2C锟斤拷锟斤拷锟绞高碉拷平时锟斤拷锟斤拷锟斤拷 锟斤拷锟街�锟斤拷锟斤拷小锟斤拷3
- #elif defined IIC_1M
- newStruct_I2C.m_BaudRateL = 20; //I2C锟斤拷锟斤拷锟绞低碉拷平时锟斤拷锟斤拷锟斤拷 锟斤拷锟街�锟斤拷锟斤拷小锟斤拷3
- newStruct_I2C.m_BaudRateH = 20; //I2C锟斤拷锟斤拷锟绞高碉拷平时锟斤拷锟斤拷锟斤拷 锟斤拷锟街�锟斤拷锟斤拷小锟斤拷3
- #endif
- newStruct_I2C.m_AckEn = TRUE;
- newStruct_I2C.m_AckData = I2C_ACKDATA_ACK;
- I2C_Configuration(I2Cx, &newStruct_I2C);
- //I2C_Cmd(I2Cx,TRUE);
- I2C_Clear_INTERRUPT_Flag(I2Cx);
- //I2C_MATCH_ADDRESS_Config(I2Cx,TRUE);
- //I2C_ISIE_INT_Enable(I2Cx, TRUE);
- //I2C_SCL_Enable(I2Cx,TRUE);
- I2C_Cmd(I2Cx,TRUE);
- void I2C_Byte_Write(uint16_t slave_addr,uint16_t reg_Addr,uint32_t I2C_data, FunctionalState NewState )
- I2C_Choose=I2C0_SFR;
- static uint8_t I2C_SLAVE_ADDRESS10BH=0;
- static uint8_t I2C_SLAVE_ADDRESS10BL=0;
- I2C_Generate_START(I2C_Choose,TRUE);
- while(!I2C_Get_INTERRUPT_Flag(I2C_Choose));
- I2C_SendData8(I2C_Choose,slave_addr);
- I2C_Clear_INTERRUPT_Flag(I2C_Choose);
- while(I2C_Get_Ack_Fail_Flag(I2C_Choose));
- I2C_SendData(I2C_Choose,reg_Addr);
- if(NewState)
- I2C_SendData(I2C_Choose,I2C_data);
- /*停止位*/
- I2C_Generate_STOP(I2C_Choose,TRUE);
- I2C_Clear_Stop_Flag(I2C_Choose);
- void I2C_Byte_read(uint16_t slave_addr,uint8_t *I2C_data )
- while(!I2C_Get_Start_Flag(I2C_Choose));
- I2C_SendData8(I2C_Choose,slave_addr|0x01);
- while((I2C_Choose->SR &I2C_SR_RCBF)== 0);
- *I2C_data = I2C_ReceiveData(I2C_Choose);
- // I2C_Clear_INTERRUPT_Flag(I2C_Choose);
- //while(!I2C_Get_INTERRUPT_Flag(I2C_Choose));
- I2C_Ack_DATA_Config(I2C_Choose,I2C_ACKDATA_NO_ACK);
- /* Stop bit */
- I2C_Generate_STOP(I2C_Choose, TRUE);
- /* Clear the ISIF bit of the I2C interrupt flag */
- /* Wait for the stop to complete */
- while (!I2C_Get_INTERRUPT_Flag(I2C_Choose)) ;
- /* Clear the I2C stop flag PIF bit */
- * bsp_iic.h
- * Author: pc
- #ifndef I2C_Master_Slave_H_
- #define I2C_Master_Slave_H_
- #include "system_init.h"
- #define MODE_Master 1
- #define MODE_Slave 0
- #define IIC_MODE MODE_Master
- #define IIC_10BIT_Address 0
- //#define IIC_100K 100000
- #define IIC_400K 400000
- //#define IIC_1M 1000000
- #define I2C_OK 1
- #define I2C_FAIL 0
- void I2C_GPIO_init(void);
- void I2C_init_Slave(I2C_SFRmap* I2Cx,uint16_t I2C_ADDRESS);
- void I2C_init_Master(I2C_SFRmap* I2Cx);
- void I2C_Byte_Write(uint16_t slave_addr,uint16_t reg_Addr,uint32_t I2C_data, FunctionalState NewState );
- void I2C_Byte_read(uint16_t slave_addr,uint8_t *I2C_data);
- #endif
- * PCF8563.c
- * Created on: 2022-6-29
- * Author: pc
- #include "PCF8563.h"
- unsigned char PCF8563_WriteByte(uint16_t Write_i2c_Addr,uint32_t I2C_data)
- I2C_Byte_Write(0xA2,Write_i2c_Addr, I2C_data,TRUE);
- unsigned char PCF8563_ReadByte(uint16_t Write_i2c_Addr )
- uint8_t temp = 0;
- I2C_Byte_Write(0xA2,Write_i2c_Addr, 0,FALSE);
- systick_delay_us(10);
- I2C_Byte_read(0xA2,&temp);
- return temp;
- void PCF8563_Timer_Disable(void)
- PCF8563_WriteByte(PCF8563_Address_Control_Status_2, (PCF8563_ReadByte(PCF8563_Address_Control_Status_2)&0xfe));
- PCF8563_WriteByte(TIMER_CTRL_BUF, PCF8563_ReadByte(TIMER_CTRL_BUF)&0x7f);
- void PCF8563_Alarm_Disable(void)
- PCF8563_WriteByte(0x01, (PCF8563_ReadByte(0x01)&0xfd));
- PCF8563_WriteByte(PCF8563_Alarm_Minutes, PCF8563_ReadByte(PCF8563_Alarm_Minutes)|0x80);
- PCF8563_WriteByte(PCF8563_Alarm_Hours, PCF8563_ReadByte(PCF8563_Alarm_Hours)|0x80);
- PCF8563_WriteByte(PCF8563_Alarm_Days,0x80);
- PCF8563_WriteByte(PCF8563_Alarm_WeekDays,0x80);
- char PCF8563_Init(void)
- PCF8563_WriteByte(PCF8563_Address_Control_Status_1,0x00);
- PCF8563_WriteByte(PCF8563_Address_Control_Status_2,0x00);
- PCF8563_Timer_Disable();
- PCF8563_Alarm_Disable();
- void PCF8563_Set_Time(int hour, int minute, int second)
- if(hour>=0){
- hour = changeIntToHex(hour%60);
- PCF8563_WriteByte(HOUR_DATA_BUF, hour);
- if(minute>=0){
- minute = changeIntToHex(minute%60);
- PCF8563_WriteByte(MINUTE_DATA_BUF, minute);
- if(second>=0){
- second = changeIntToHex(second%60);
- PCF8563_WriteByte(SECOND_DATA_BUF, second);
- void PCF8563_Set_Alarm(int hour, int minute)
- if(minute >= 0){
- minute = changeIntToHex(minute);
- PCF8563_WriteByte(MINUTE_AE_BUF, minute);
- if(hour >= 0){
- hour = changeIntToHex(hour);
- PCF8563_WriteByte(HOUR_AE_BUF, hour);
- void PCF8563_Set_Days(int year, int months, int days)
- if(days >= 0 && days <= 31){
- days = changeIntToHex(days);
- PCF8563_WriteByte(DAY_DATA_BUF, days);
- if(months>=0 && months <= 12 ){
- months = changeIntToHex(months);
- PCF8563_WriteByte(MONTH_DATA_BUF, (PCF8563_ReadByte(MONTH_DATA_BUF)&0x80)| months);
- if(year>=1900 && year<2000){
- PCF8563_WriteByte(MONTH_DATA_BUF, PCF8563_ReadByte(MONTH_DATA_BUF) | 0x80);
- PCF8563_WriteByte(YEAR_DATA_BUF, year%100);
- }else if(year>= 2000 && year < 3000){
- PCF8563_WriteByte(MONTH_DATA_BUF, PCF8563_ReadByte(MONTH_DATA_BUF) & 0x7F);
- unsigned char PCF8563_Check(void)
- uint8_t temp = 0;
- unsigned char Time_Count = 0;
- if(PCF8563_ReadByte(PCF8563_Address_Timer) & 0x80)
- PCF8563_WriteByte(PCF8563_Address_Timer,PCF_Timer_Close);
- Time_Count = PCF8563_ReadByte(PCF8563_Address_Timer_VAL);
- PCF8563_WriteByte(PCF8563_Address_Timer_VAL,0xAA);
- temp = PCF8563_ReadByte(PCF8563_Address_Timer_VAL);
- if(0xAA != temp)
- temp = 0;
- fprintf(USART0_STREAM,"PCF8563 Check Error\r\n");
- }else{
- temp = 1;
- fprintf(USART0_STREAM,"PCF8563 Check Success\r\n");
- if(Time_Count != 0)
- PCF8563_WriteByte(PCF8563_Address_Timer_VAL, Time_Count);
- PCF8563_WriteByte(PCF8563_Address_Timer, PCF_Timer_Open);
- return temp;
- void PCF8563_Set_Timer(int Timer_Frequency ,unsigned char Value)
- // PCF8563_WriteByte(TIMER_CTRL_BUF, PCF8563_ReadByte(TIMER_CTRL_BUF)&0x7f);
- PCF8563_WriteByte(COUNT_VAL_BUF, Value);
- if(Timer_Frequency == 4096){
- PCF8563_WriteByte(TIMER_CTRL_BUF, ((PCF8563_ReadByte(TIMER_CTRL_BUF))&0xfc)|TIMER_FREQUENCY_4096);
- }else if(Timer_Frequency == 64){
- PCF8563_WriteByte(TIMER_CTRL_BUF, ((PCF8563_ReadByte(TIMER_CTRL_BUF))&0xfc)|TIMER_FREQUENCY_64);
- }else if(Timer_Frequency == 1){
- PCF8563_WriteByte(TIMER_CTRL_BUF, ((PCF8563_ReadByte(TIMER_CTRL_BUF))&0xfc)|TIMER_FREQUENCY_1);
- }else if(Timer_Frequency == 0){// 1/60
- PCF8563_WriteByte(TIMER_CTRL_BUF, ((PCF8563_ReadByte(TIMER_CTRL_BUF))&0xfc)|TIMER_FREQUENCY_1_60);
- }else{
- printf("Set Timer Error\r\n");
- void PCF8563_CLKOUT_FrequencyHZ(unsigned char Frequency)
- if(Frequency == 32768){
- PCF8563_WriteByte(CLK_FRQ_BUF, (PCF8563_ReadByte(CLK_FRQ_BUF)&0xfC)|0x00);
- }else if(Frequency == 1024){
- PCF8563_WriteByte(CLK_FRQ_BUF, (PCF8563_ReadByte(CLK_FRQ_BUF)&0xfC)|0x01);
- }else if(Frequency == 32){
- PCF8563_WriteByte(CLK_FRQ_BUF, (PCF8563_ReadByte(CLK_FRQ_BUF)&0xfC)|0x02);
- }else if(Frequency == 1){
- PCF8563_WriteByte(CLK_FRQ_BUF, (PCF8563_ReadByte(CLK_FRQ_BUF)&0xfC)|0x03);
- }else {
- printf("Set CLKOUT requency Selection Error\r\n");
- void PCF8563_Alarm_Enable(void)
- PCF8563_WriteByte(0x01, (PCF8563_ReadByte(0x01)|0x02));
- PCF8563_WriteByte(MINUTE_AE_BUF, PCF8563_ReadByte(MINUTE_AE_BUF)&0x7f);
- PCF8563_WriteByte(HOUR_AE_BUF, PCF8563_ReadByte(HOUR_AE_BUF)&0x7f);
- PCF8563_WriteByte(DAY_AE_BUF,0x80);//鍏抽棴
- PCF8563_WriteByte(WEEK_AE_BUF,0x80);//鍏抽棴
- void PCF8563_Timer_Enable(void)
- PCF8563_WriteByte(0x01, (PCF8563_ReadByte(0x01)|0x01));
- PCF8563_WriteByte(TIMER_CTRL_BUF, PCF8563_ReadByte(TIMER_CTRL_BUF)|0x80);
- void PCF8563_CLKOUT_Enable(void)
- PCF8563_WriteByte(CLK_FRQ_BUF, PCF8563_ReadByte(CLK_FRQ_BUF)|0x80);
- void PCF8563_Get_Time(unsigned char *buf)
- buf[0] = PCF8563_ReadByte(SECOND_DATA_BUF) & 0x7f; //get second data
- buf[1] = PCF8563_ReadByte(MINUTE_DATA_BUF) & 0x7f; //get minute data
- buf[2] = PCF8563_ReadByte(HOUR_DATA_BUF) & 0x3f; //get hour data
- buf[0] = changeHexToInt(buf[0]);
- buf[1] = changeHexToInt(buf[1]);
- buf[2] = changeHexToInt(buf[2]);
- unsigned char PCF8563_Get_Flag(void)
- unsigned char temp=0;
- if(PCF8563_ReadByte(0x01)&0x08){
- temp = temp|0x01;
- if(PCF8563_ReadByte(0x01)&0x04){
- temp = temp|0x02;
- return temp;
- void PCF8563_Get_Days(unsigned char *buf)
- buf[0] = PCF8563_ReadByte(DAY_DATA_BUF)&0x3f;
- buf[1] = PCF8563_ReadByte(MONTH_DATA_BUF) & 0x1f;
- buf[2] = PCF8563_ReadByte(YEAR_DATA_BUF)&0xff;
- if(PCF8563_ReadByte(MONTH_DATA_BUF) & 0x80){
- buf[3] = 19;
- }else{
- buf[3] = 20;
- void PCF8563_Cleare_AF_Flag(void)
- PCF8563_WriteByte(0x01, PCF8563_ReadByte(0x01)&0xf7);
- void PCF8563_Cleare_TF_Flag(void)
- PCF8563_WriteByte(0x01, PCF8563_ReadByte(0x01)&0xfB);
