https://www.wallystech.com/Network_Card/DR9074-5G-PN02.1-Wifi-6-Qualcomm-QCN9074-Single-Band-5-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html
Features
■ Qualcomm Atheros QCN9074
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
■ Supports Dynamic Frequency Selection (DFS)
Parameter | Rating | Unit | Operating Temperature Range | -20 to 70 | ºC | Storage Temperature Range | -40 to 90 | ºC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol
| Parameter
| Chipset
| WLAN Host Interface
| System Memory
| 2Mbit serial I²C bus EEPROM
| Standard Operating Voltage
| 5V
| Operating Systems
| QSDK
| Host Interface
| M.2 E Key
| Antenna Cable / Port
| 4 x MMCX Connectors,4T4R
| Frequency Range
| 5.15GHz-5.95GHz
| Data Rates for WALN
| Channel Spectrum Widths for WLAN
| Support 20/40/80/160MHz at 5GHz
| Modulation Techniques
| OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
| Temperature Range
| Operating: -20°C to 70°C, Storage: -40°C to 90°C
| Humidity
| Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
| Certification
| TBD
| Power Consumption
| TBD
| Reference Design
| PN02.1
| Dimensions (WxHxD)
| 57mm x 63mm x 6mm
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
We are engaged in the design and manufacture of wireless communication products, providing OEM/ODM/JDM services.
Dedicated to innovative design for RF wireless modules and host boards, Wallys also provides Software & Hardware design, product testing and certification and fully customized solution to meet your personal requirement.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344/AR9531
WEB:https://www.wallystech.com/d
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales1@wallystech.com
