[WIFI模块] IPQ8074A Qualcomm Atheros/Industrial Wifi Router Wallys/802.11ax/DR8074A
 楼主| lilywallys 发表于 2022-11-10 11:47 | 显示全部楼层 |阅读模式
#技术资源# IPQ8074 is a WiFi6 solution with the ability to handle a number of unique features from Qualcomm, including MU-MIMO Uplink, OFDMA-UL, MU-RTS (Multi User Request To Send), Preamble Junction, and Spatial Reuse (OBSS PD) functions. This allows for a higher payload data rate and more stable wireless data rate, same as an anti-interference ability that is better than Q8074A. In addition to its networking capabilities, it also supports external 5G modules, Bluetooth, ZigBee, and PCIe 2xUSB/GSBI.
This product can be used in a variety of applications, including external 5G modules, Bluetooth and ZigBee. It is also designed to provide high availability by reserving PCIe 3g bandwidth for high speed USXGMII connections up to 10Gbps.
DR8074A is designed to work with carrier's existing infrastructure and provide the best user experience. With Qualcomm Atheros IPQ8074A AR Quad Core CPU, you can experience fast data transfer speeds and more capacity for your network.
We know that your business depends on fast, reliable wireless connectivity. That's why we've created DR8074A, a powerful 5G wireless router with a powerful processor and outstanding features.
With DR8074A, you'll be able to take advantage of the latest in wireless technology—including the Qualcomm Atheros IPQ8074A AR Quad Core CPU and an on-board 5GHz radio that supports up to 4804Mbps physical data rate—all while maintaining low latency and high throughput. And with its impressive range (up to 12 miles), you'll free to set up anywhere in your network and reach every device.
DR8074A also comes equipped with a 2.4GHz radio that supports up to 1147Mbps physical data rate, so you can maintain high speeds without sacrificing coverage or bandwidth. And it comes with 11ax TX Beamforming, which allows you to pinpoint the best location for each device, making sure they're using their most efficient connection. And when it comes time for Wi-Fi calling or video streaming in your home office? You can use its support for 11ac/ax MU-MIMO DL and UL, allowing you to connect multiple devices at once without slowing down anyone else's connection!
Click below the link for get more information about DR8074A
https://www.wallystech.com/Routerboard/DR8074A-HK01-wifi6-Qualcomm-IPQ8074A-4T4R-2-4GHz-and-8T8R-5GHz-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
Visit our website:https://www.wallystech.com/
If you're interested in learning more about this product or how we can help your company with the best wireless connectivity possible, please don't hesitate to reach out!
快速回复 返回顶部 返回列表
