[WIFI模块] Industrial Wifi Router Wallys/IPQ8072A QCN9074 Qualcomm Atheros 802.11ax/DR8072V01
 楼主| lilywallys 发表于 2022-11-11 15:19 | 显示全部楼层 |阅读模式
COM, ST, TE
The IPQ8074 is Qualcomms first 802.11ax network solution, designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the optimal 11ax configuration to bring unprecedented capacity and coverage to Wi-Fi networks, and supports several unique features to ensure the best possible Wi-Fi performance for all types of applications.
High-capacity
Dense networks
In a dense network environment where there are more clients connected at any given time than can be supported by traditional Wi-Fi solutions, it is important that you carry enough bandwidth over your network connections in order to deliver a high quality experience for all users on your network. The IPQ8074 SoC delivers up to 3x higher throughput than previous generations while consuming up to 40% less power compared with previous generations of routers
Ready to take your wireless experience to the next level?
The DR8072V01 is here to help. It's an easy-to-use, powerful, and affordable device that gives you a wealth of features, including:
Qualcomm Atheros IPQ8072A AR Quad Core CPU
On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
8 MB NOR Flash, 256MB NAND FlashNAND Flash can be up to 1GB as optional)
Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
Supports Dynamic Frequency Selection (DFS)
DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
The DR8072V01 supports the Qualcomm Atheros IPQ8072A AR Quad Core CPU, which features on-board 5GHz radio, up to 2475 Mbps physical data rate, and on-board 2.4GHz radio, up to 1147Mbps physical data rate. It has 8 MB NOR Flash, 256MB NAND Flash (NAND Flash can be up to 1GB as optional), support 11ax TX Beamforming, support 11ac/ax MU-MIMO DL and UL, supports Dynamic Frequency Selection (DFS), DDR 1GB DDR3L (support DDR3L can be up to 2GB as optional) M.2 connector can support QCN9074 production
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Visit our website:https://www.wallystech.com/
If you're interested in learning more about this product or how we can help your company with the best wireless connectivity possible, please don't hesitate to reach out!
快速回复 返回顶部 返回列表
