[WIFI模块] 802.3BT/AT/AF support Industrial Wifi Router Wallys/PD60
 楼主| lilywallys 发表于 2022-11-16 10:53 | 显示全部楼层 |阅读模式
It's easy to get confused about what type of power y**ices need, especially when you're dealing with PoE. Here are the main categories of PoE and how they work:802.3BT/AT/AF
1. 802.3af: Provides up to 15.4W and is most commonly used for wireless access points and IP cameras, but can also be used for VoIP phones if they don't need much power.
2. 802.3at: Provides up to 30W and is often referred to as "PoE+" on most switches. The higher amount of power allows better quality cameras to be used, such as 4K cameras and PoE switches which are powered up by PoE and provide power down stream, such as the UniFi Switch Flex from Ubiquiti, it is powered by 802.3at on the uplink and can provide 802.3af PoE on four other ports.
802.3bt: Provides 60W to each device it is referred to as PoE++ usually (only available in some countries). This is used for really demanding devices, notably lighting products and screens
Is there a router could fit the 3 PoE in 1 device?
Today I’ll introduce you a wallys router PD-60.
The PD-60 is a routerboard that supports 802.3BT/AT/AF, which means it can connect with other routers to form a high-speed network. The output voltage is 48V, and the efficiency is 90%.
It also has surge protection, which means it will protect your network from power surges that might damage your equipment. And since it's RoHS compliant, you can be sure that it's made with materials that don't pose any risk to human health or the environment.
For more information about PD-60,you can click the link below or email us.
https://www.wallystech.com/Routerboard/PD60-802.3-af-at-active-POE-to-Passive-POE-24V-adapter.html
If you're looking for a company that can provide reliable and cost-effective routerboards and wireless network cards, you've come to the right place!
Wallys has been in the wireless industry for over 15 years and has designed and manufactured many high-quality products.We have a strong track record of providing customized solutions based on your specifications, so let us know if you have any questions.
If you would like to learn more about our products or contact us directly, please feel free to shoot us a message!
Email:sales1@wallystech.com
Wallys Communications (SuZhou) Co.,Ltd
http://www.wallystech.com
快速回复 返回顶部 返回列表
