IPQ8072A QCN9074 high power industrial wifi router support openWRT/Wallys 802.11ax boards DR8072 V01
802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi.
Here are wallys 802.11ax boards and cards.
DR6018 V4
DR6018C V01
DR6018-S V02
DR8072 V01
DR5018
DR9074-6E(PN02.7)
DR9074-5G(PN02.1)
DR9074-2.4G(PN01.1)
We have introduced DR6018V4 in previous article and today let’s talk about the DR8072 V01.
DR8072 V01
This is a router board integrated with Qualcomm Atheros IPQ8072A AR Quad Core CPU,Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL,and the System Memory is DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional).8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional),Supports Dynamic Frequency Selection (DFS),On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate,M.2 connector can support QCN9074 production
https://www.wallystech.com/upload/1639621845c333290bcff352fc33fb6c918f2865de.png
Regard to the Absolute Maximum Rating,we’ll introduce from 4 perspectives parameters:Operating Temperature Range,Storage Temperature Range,Operating Humidity Range and Storage Humidity Range.
For the Operating Temperature Range,it is -20 to +70ºC.
For the Storage Temperature Range,it is -40 to +90ºC.
For the Operating Humidity Range,it is 5 to +95 (non-condensing)%.
For the Storage Humidity Range,It is 0 to +90 (non-condensing)%.
Regard to the Hardware Specifications,we’ll introduce from 14 perspectives:
For the CPU,it is Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU.
For the CPU Frequency,it is Derived from Qualcomm Atheros AP.HK09.
For the System Memory,it is 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional).
For the Frequency Range,It is 2.412~2.472GHz, 5.150~5.825GHz
For the M.2 Slot,It is 1x M.2 Slot with PCIe 3.0
For the Modulation Techniques,It is OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
For the Environmental Temperature,It is Operating: -20ºC to 70ºC, Storage: -40ºC to 90ºC
For the Flash,It is NOR Flash: 8 MB NAND Flash: 256MB(1GB optional)
For the Wireless,It is On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain;On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain ;8x U.FL Connectors
For the Reset Buttons,It is 1x S/W Reset Button
For the DC Jack Input,It is 1x DC Jack Connector: 12V
For the Interface,It is 4x 1Gbps Ethernet Port;1x 10Gbps Ethernet Port ;1x 10Gbps SFP;2x USB 3.0 Port ;1x JTAG 20 Pin Connector ;1x Serial Port 4 Pin Connector
For the LED,It is 2x RGB LED Indicators
For the Power Consumption,It is TBD
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
For more information,visit our website:https://www.wallystech.com/
