- * Copyright (C) 2020, Huada Semiconductor Co., Ltd. All rights reserved.
- * This software component is licensed by HDSC under BSD 3-Clause license
- * (the "License"); You may not use this file except in compliance with the
- * License. You may obtain a copy of the License at:
- * opensource.org/licenses/BSD-3-Clause
- /** \file main.c
- ** \brief This sample demonstrates how to set GPIO as output function.
- ** - 2018-10-14 CDT first version for Device Driver Library of GPIO.
- * Include files
- #include "hc32_ddl.h"
- * Local type definitions ('typedef')
- * Local pre-processor symbols/macros ('#define')
- /* LED0 Port/Pin definition */
- #define LED0_PORT (PortE)
- #define LED0_PIN (Pin06)
- /* LED1 Port/Pin definition */
- #define LED1_PORT (PortA)
- #define LED1_PIN (Pin07)
- /* LED2 Port/Pin definition */
- #define LED2_PORT (PortB)
- #define LED2_PIN (Pin05)
- /* LED3 Port/Pin definition */
- #define LED3_PORT (PortB)
- #define LED3_PIN (Pin09)
- /* LED0~3 toggle definition */
- #define LED0_TOGGLE() (PORT_Toggle(LED0_PORT, LED0_PIN))
- #define LED1_TOGGLE() (PORT_Toggle(LED1_PORT, LED1_PIN))
- #define LED2_TOGGLE() (PORT_Toggle(LED2_PORT, LED2_PIN))
- #define LED3_TOGGLE() (PORT_Toggle(LED3_PORT, LED3_PIN))
- #define DLY_MS (100ul)
- * Global variable definitions (declared in header file with 'extern')
- * Local function prototypes ('static')
- * Local variable definitions ('static')
- * Function implementation - global ('extern') and local ('static')
- ** \brief Main function of GPIO output
- ** \param None
- ** \retval int32_t Return value, if needed
- int32_t main(void)
- stc_port_init_t stcPortInit;
- /* configuration structure initialization */
- MEM_ZERO_STRUCT(stcPortInit);
- stcPortInit.enPinMode = Pin_Mode_Out;
- stcPortInit.enExInt = Enable;
- stcPortInit.enPullUp = Enable;
- /* LED0 Port/Pin initialization */
- PORT_Init(LED0_PORT, LED0_PIN, &stcPortInit);
- /* LED1 Port/Pin initialization */
- PORT_Init(LED1_PORT, LED1_PIN, &stcPortInit);
- /* LED2 Port/Pin initialization */
- PORT_Init(LED2_PORT, LED2_PIN, &stcPortInit);
- /* LED3 Port/Pin initialization */
- PORT_Init(LED3_PORT, LED3_PIN, &stcPortInit);
- while(1)
- LED0_TOGGLE();
- Ddl_Delay1ms(DLY_MS);
- LED1_TOGGLE();
- LED2_TOGGLE();
- LED3_TOGGLE();
- /* de-init if necessary */
- //PORT_DeInit();
- * EOF (not truncated)
